HP Tower Uninterruptible Power Systems (UPS) provide advanced power protection and secure your computer equipment and your critical data against damage due to inconsistent and fluctuating power. Designed for small/medium businesses, HP UPSs lower your power protection cost by allowing you to safeguard all of your equipment. Key benefits include increased power rating, an intuitive front panel display, Enhanced Battery Management (EBM), prioritized shut-down, hot-swappable battery, network transient protection, and a serial and USB ports for data exchange with the host computer.
HP Power Manager software (free with all HP UPSs) provides the flexibility to monitor power conditions and control the HP UPS locally or remotely, enables you to broadcast alarms, perform orderly shutdowns in the event of power failures, and allows you to schedule power-on and power-off to the UPS and attached equipment.
With HP Care Pack Services, have the security of knowing that your HP UPS will be covered at the same service level and coverage period as your HP server.
- HP UPS T1500 G3 - UPS - 1400 VA
- UPS - external
- 17 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- + 6% / - 10%
- Power Capacity
- 1400 VA
- Output Connector(s)
- 6 x power IEC 320 EN 60320 C14
- Battery
- Lead Acid
- Run Time (Up To)
- 5 min at full load
- 15 cm x 39 cm x 19.3 cm
- 3 years warranty
- Designed For
- ProLiant DL165 G7, DL360p Gen8, DL370 G6, DL380p Gen8, ML110 G6, ML110 G7, ML150 G6, ML310e Gen8, ML330 G6, ML350 G6, ML350e Gen8, ML350p Gen8, ML370 G6
- UPS - external
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Frequency Required
- 50/60 Hz
- Input Connector(s)
- 1 x power IEC 320 EN 60320 C13
- Power Output Connectors Details
- Output Voltage
- + 6% / - 10%
- Power Capacity
- 1400 VA
- Output Waveform
- Sinewave
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 24 hours
- 1 x management (USB) , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
- Cables Included
- 1 x USB cable - external - 1.8 m , 1 x serial cable - external - 1.8 m
- Equipment Protection Value
- 250000 US Dollars
- LED display, audible alarm
- UL, VCCI, C-Tick, GOST, GS, NOM, EK, FCC, RoHS, ICES, S Mark
- Software Included
- Drivers & Utilities
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95%
- Sound Emission
- 45 dBA
- 15 cm
- 39 cm
- 19.3 cm
- 17 kg
- Designed For
- HP ProLiant DL165 G7, DL165 G7 Base, DL360p Gen8, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, ML110 G6, ML110 G7, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350p Gen8, ML350p Gen8 Base, ML370 G6, ML370 G6 Base, ML370 G6 Entry
