HP EliteDisplay E242 LED 24" Monitor 1920 x 1200 IPS
Quicklinx: BXQTWS00 Mfr#: M1P02AA#ABU
Be a master at multi-tasking with HP EliteDisplay E242 61 cm (24") Monitor, which delivers Full HD resolution, TCO Edge Certified comfort features, and an extra-large screen for all of your work.
  • A compact, efficient PC-and-monitor workspace
    Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
  • Reduce power consumption and help lower costs
    Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements.
  • Your monitor's new best friend
    Design the screen for how you work with HP Display Assistant software.
  • Make it yours
    Customize a complete solution with HP accessories designed and tested to work with your display.
HP EliteDisplay E242 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 120/230 V
56.22 cm x 18.9 cm x 51.9 cm
6.23 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, SEPA
3-year warranty
Display Type
Energy Class
Class A
33 kWh
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
7 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Mercury free, arsenic-free glass
56.22 cm x 18.9 cm x 51.9 cm - with stand
6.23 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x VGA cable , 1 x DisplayPort cable , 1 x USB cable
Input Voltage
AC 120/230 V
22 W
Power Consumption (Typical)
38 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Dimensions & Weight Details
Without stand - width: 56.22 cm - depth: 5 cm - height: 37.74 cm - weight: 4.2 kg , With stand - width: 56.22 cm - depth: 18.9 cm - height: 51.9 cm - weight: 6.23 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80%
