Move your business beyond paper-intensive processes. Integrate with existing networked manageability and security solutions. Improve workflows by creating a virtually unlimited number of scan profiles and reliably handle up to 5,000 pages a day.
Enjoy forward-looking, high-speed productivity
Reclaim your time. Scan up to 60 pages per minute and 120 images per minute – even do two-sided scans.Easily manage jobs on the 20.3cm (8-inch) HP Easy Select touchscreen colour control panel with pullout keyboard.Do more with data using multiple scan-to options – folders, FTP sites, email, USB drives, SharePoint and more.Expand capture capabilities and seamlessly integrate solutions through the hardware integration pocket. -
Outstanding content management and easy collaboration
Get high-volume performance, time and again – scan up to 5,000 pages daily with minimal user intervention.Bring data to life with built-in OCR capabilities, then save scans in a variety of file formats.Get fast results from single-pass scanning and HP EveryPage. Automatically remove blank pages.Manage big jobs with the 100-sheet automatic document feeder. Reliably handle scan jobs with mixed originals. -
Get the digital sending security your business demands
Scan and send documents without worry – the HP High-Performance Secure Hard Disk helps keep sensitive data safe.Maintain security throughout the document lifecycle by enabling a variety of authentication options.Easily manage who can scan and where files can be saved, using advanced security features – including IPSec.Enable easy sharing of sensitive data when you create encrypted, password-protected PDFs. -
Seamless management from the very start
Proactively and centrally manage the device with the rest of your imaging and printing environment.Expand workteam capabilities within your print environment, using a rich array of easy-to-integrate solutions.Redefine workflows and help reduce distribution costs, using optional HP Capture and Route software.Create advanced, custom workflows across a variety of devices, using optional HP Digital Sending Software.
- HP Digital Sender Flow 8500 fn1 Document Capture Workstation - document scanner - desktop - USB 2.0, Gigabit LAN
- Document scanner - desktop
- Interface Type
- Scanning Sensor Type
- Flatbed: CCD / ADF: CIS
- Light Source
- LED
- Additional Functions
- Email, fax, scan to network share
- Max Supported Document Size
- A4 (210 x 297 mm)
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 60 ppm (mono) / 45 ppm (colour)
- Max Document Size
- 210 mm x 297 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, plastic card, labels, photo
- Document Feeder Type
- Manual, automatic
- Document Storage Capacity
- 100 sheets
- Duty Cycle
- 5000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- 52.07 cm x 53.34 cm x 30.81 cm
- 20.18 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- A4 (210 x 297 mm)
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 60 ppm
- Max Document Scan Speed Colour
- 45 ppm
- Duty Cycle
- Scanner Features
- Built-in High Performance Secure Hard Disk, 8" touch screen TFT display, Ultrasonic Multi Feed Detection, built-in keyboard, Hardware Integration Pocket (HIP)
Media Handling
- Max Document Size
- 210 mm x 297 mm
- Manual, automatic
- 100 sheets
- Interfaces Details
- Gigabit LAN , USB 2.0 - Type A
- CSA, C-Tick, BSMI, CISPR 22 Class A, GOST, CISPR 24, EN55024, EN55022 Class A, CB, CCC, EMC, FCC, UL 60950-1 Second Edition, KCC, IEC 60950-1 Second Edition, EN 61000-3-2:2006, EN 60950-1:2006, EN 61000-3-3:1995+A1:2001+A2:2005, CAN/CSA-C22.2 No. 60950-1
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 70 Watt (24 Watt)
- Software Included
- I.R.I.S. OCR
- 52.07 cm
- 53.34 cm
- 30.81 cm
- 20.18 kg
- Shipping Width
- 63 cm
- Shipping Depth
- 60.1 cm
- Shipping Height
- 42.8 cm
- Shipping Weight
- 23.5 kg
- 10 °C
- 35 °C
- 15 - 80% (non-condensing)
