Print, scan and copy everyday documents with this simple and affordable HP Deskjet all-in-one. Save space with a compact design that fits anywhere and get started in no time with quick and easy setup.
Print, scan and copy with one affordable device
Enjoy real versatility – produce everything you need with this no-fuss all-in-one.Do it all from one affordable device – print web pages, scan photos, copy correspondence and more.Print and copy with laser-quality text and vivid colour graphics using affordable HP ink cartridges.Get up to 2.5x more black printed pages and 2x more colour printed pages with optional high-capacity ink cartridges. -
Get started straightaway with quick, easy set-up and intuitive operation
No waiting – installs right out of the box in just a few minutes.Print, scan and copy with an all-in-one designed for simple operation – just four buttons.Get performance you can rely on with HP Deskjet – the world's No.1 printer brand.Start even faster on HP PCs running Windows 8. -
Save space with a sleek, stylish and compact design
Save valuable space with a compact all-in-one that's designed fit almost anywhere.Keep it close to hand on your desk, or neatly out of the way on a shelf.Conserve energy – and save money – with this ENERGY STAR qualified printer.
- HP Deskjet 1510 All-in-One - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 300 - 400 pages
- Max Copying Speed
- Up to 4.5 ppm (mono) / up to 3 ppm (colour)
- Max Copying Resolution
- Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
- Max Printing Speed
- Up to 7 ppm (mono) / up to 4 ppm (colour)
- Max Printing Resolution
- Up to 600 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Size
- 216 x 297 mm (max)
- Media Size
- 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, greeting cards, photo paper
- Standard Media Capacity
- 60 sheets
- Output Trays Capacity
- 25 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 110/230 V (50/60Hz)
- 42.523 cm x 30.582 cm x 15.66 cm
- 3.6 kg
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified
- Ink-jet - colour
- 1000 pages
- 300 - 400 pages
- Interface
- USB 2.0
Copying
- Max Copying Speed
- Maximum Copies
- 9
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 17 sec
- First Print Out Time Colour
- 24 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 101.6 x 152.4 mm, 89 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215 x 279 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm)
- 60 sheets
- 25 sheets
- Input tray - 60 sheets - Legal (216 x 356 mm) , Output tray - 25 sheets
- Speed Details
- Printing: up to 7 ppm - B/W (ISO) , Printing: up to 4 ppm - colour (ISO) , Printing: up to 20 ppm - B/W draft , Printing: up to 16 ppm - colour draft , Copying: up to 4 ppm - B/W draft , Copying: up to 2 ppm - colour draft , Copying: up to 4.5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO)
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
- Software Included
- Drivers & Utilities
- Voltage Required
- 10 Watt
- Power Consumption Standby
- 2 Watt
- Power Consumption Sleep
- 0.9 Watt
- CISPR 24, CISPR 22, IEC 60950-1, FCC CFR47 Part 15 B, LVD, EN 61000-3-3:2008, ICES-003 issue 4 Class B, NOM-019-SCFI-1993 IRAM, EN 61000-3-2:2006+A1:2009+A2:2009
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- 42.523 cm
- 30.582 cm
- 15.66 cm
- 3.6 kg
- Shipping Width
- 46.3 cm
- Shipping Depth
- 35.4 cm
- Shipping Height
- 19.3 cm
- Shipping Weight
- 5.2 kg
- Sound Emission
- 54 dBA (operating)
- 5 °C
- 40 °C
- 15 - 80% (non-condensing)
HP 301XL High Yield Tri-colour Original Ink Cartridge | In Stock | £30.83 |
