HP Deskjet 1110 Colour InkJet Printer
Quicklinx: BT5YWS00 Mfr#: F5S20B#BEV
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Print the documents you need in a snap. Designed to fit tight spaces and budgets, this printer is simple to set up and use right out of the box. Count on high-quality prints while also conserving energy with a printer that's ENERGY STAR certified.
  • Enjoy printing made simple
    No need to wait. Start printing right out of the box with easy setup.
  • Count on a product designed to fit your life
    Save your space with a compact printer designed to fit on your desk, on a shelf or anywhere you need it.
  • Experience affordable at-home printing
    Print more for less, using the world's No. 1 printer brand plus Original HP ink cartridges.Full of value – print up to twice as many pages with Original HP high-yield ink cartridges.
  • Reduce your impact
    Conserve resources without sacrificing performance with a printer that's ENERGY STAR certified.Reduce your environmental impact – count on easy, free cartridge recycling through HP Planet Partners.
HP Deskjet 1110 - printer - colour - ink-jet
Printer Type
Personal printer - ink-jet - colour
2.02 kg
English / United Kingdom, Ireland
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm), 215 x 279 mm
Min Media Size (Custom)
89 mm x 127 mm
Max Media Size (Custom)
215 mm x 297 mm
Print Speed
Up to 7.5 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 5.5 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
USB 2.0
Language Simulation
PCL 3
Media Type
Plain paper, photo paper
Total Media Capacity
60 sheets
Media Handling
60-sheet input tray
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 200 pages
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10
42.58 cm x 21.56 cm x 12.43 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Print Speed
Wired
USB 2.0
1200 x 1200 dpi
4800 x 1200 dpi
Language Simulation
PCL 3
Media Handling
60-sheet input tray
Media Handling
Media Type
Media Size Class
A4
Max Media Size
89 mm x 127 mm
215 mm x 297 mm
Media Sizes
A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
Envelope Sizes
International DL (110 x 220 mm)
Media Weight
60 g/m² - 300 g/m²
60 sheets
Media Feeders
1 x automatic - 60 rolls - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²
Output Trays Capacity
25 sheets
Duty Cycle
1000 pages
50 - 200 pages
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
Power supply - internal
Frequency Required
50/60 Hz
10 Watt
Power Consumption Stand by
1.3 Watt
Power Consumption Sleep
0.7 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 7/8/8.1 - 1 GHz HD 2 GB , MacOS X 10.8/10.9/10.10 - HD 1 GB
Environmental Standards
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Operating)
55 dBA
42.58 cm
21.56 cm
12.43 cm
2.02 kg
Width (Shipping)
47.3 cm
Depth (Shipping)
16.3 cm
Height (Shipping)
27.4 cm
Weight (Shipping)
2.89 kg
BT5Y HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.68
BT5Y HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.69
