HP DesignJet T3500 MFP
Quicklinx: CP0QWS00 Mfr#: B9E24A#B19
Improve productivity with the fastest MFP on the market for all your black-and-white and colour needs. Enjoy unattended operation at costs rivaling similar black-and-white LED MFPs. This MFP is built for rigorous IT demands and top security.
All your workflow needs in a high-productivity MFP
Be the fastest – print A1-size pages in 21 seconds with dark blacks, neutral greys, and vivid colours.
Print out your first page right away thanks to ultra-fast processing and zero warm-up time.
Copy and scan quickly with advanced features and efficient workflow tools – presets, batch scanning, multipage PDFs, and scan to email.
Stay organised and avoid clutter – the integrated 100-page stacker delivers prints and copies neatly collated.
A production printer for unattended, low-cost use
Print your black-and-white drawings at the same cost per page as comparable black-and-white LED MFPs.
Operate unattended thanks to two heavy rolls of up to 200 m (650 ft) and a total ink capacity of 1800 ml.
Built for high-volume printing – rely on a robust design to fulfil the most demanding jobs.
Manage projects and control costs effectively, using embedded professional accounting features.
Built for rigorous IT demands and top security
Minimise device-management tasks and costs, using the HP DesignJet Universal Print Driver.
Manage your fleet with ease, while saving time and helping to reduce costs, thanks to HP Web Jetadmin.
Protect and manage confidential jobs securely – retrieve documents at the printer with a personal PIN.
Safeguard confidential information, using a self-encrypting HDD with AES-256, Secure Disk Erase, and IPsec.
  • All your workflow needs in a high-productivity MFP
    Be the fastest – print A1-size pages in 21 seconds with dark blacks, neutral greys, and vivid colours.Print out your first page right away thanks to ultra-fast processing and zero warm-up time.Copy and scan quickly with advanced features and efficient workflow tools – presets, batch scanning, multipage PDFs, and scan to email.Stay organised and avoid clutter – the integrated 100-page stacker delivers prints and copies neatly collated.
  • A production printer for unattended, low-cost use
    Print your black-and-white drawings at the same cost per page as comparable black-and-white LED MFPs.Operate unattended thanks to two heavy rolls of up to 200 m (650 ft) and a total ink capacity of 1800 ml.Built for high-volume printing – rely on a robust design to fulfil the most demanding jobs.Manage projects and control costs effectively, using embedded professional accounting features.
  • Built for rigorous IT demands and top security
    Minimise device-management tasks and costs, using the HP DesignJet Universal Print Driver.Manage your fleet with ease, while saving time and helping to reduce costs, thanks to HP Web Jetadmin.Protect and manage confidential jobs securely – retrieve documents at the printer with a personal PIN.Safeguard confidential information, using a self-encrypting HDD with AES-256, Secure Disk Erase, and IPsec.
HP DesignJet T3500 Production eMFP - multifunction printer - colour
36" multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 6-ink
Max Printing Speed
Up to 0.35 min/page (mono) / up to 0.35 min/page (colour)
Max Printing Resolution
Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Original Size
210 x 297 mm (min) - 914 x 8000 mm, 610 x 15000 mm (max)
Media Size
914 x 1219 mm, Roll (91.4 cm x 200 m) (max)
Standard Media Capacity
2 rolls
Connection Availability
Gigabit LAN, USB 2.0 host
Office Machine Features
Automatic cutter
AC 120/230 V (50/60Hz)
140 cm x 78.4 cm x 110.9 cm
114 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
Automatic cutter
Hard Disk Drive
500 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
9632 nozzles
Max Printing Speed
Ink Cartridge Configuration
6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, photo black, pigment matte black, grey
6-ink
Printer Drivers / Emulations
TIFF, HPGL/2, HP-RTL, PCL 3 GUI, CALS G4
Scanning
Optical Resolution
600 x 600 dpi
Document & Media Handling
Min Original Size
210 x 297 mm
Max Original Size
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
328 g/m²
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), 914 x 1219 mm, Roll (91.4 cm x 200 m), 210 x 279 mm
2 rolls
Input tray - 2 rolls
Speed Details
Printing: 21 sec (A1) , Printing: 21 sec (D) , Scanning: up to 63.5 mm/sec - colour , Scanning: up to 190.5 mm/sec - B/W
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
Operating System Support
Apple Mac OS X, MS Windows
120 Watt
Power Consumption Sleep
2 Watt
FCC Class A certified, CSA, GOST, PSB, IRAM, RoHS, EN 60950-1, WEEE, REACH, ICES Class A, LVD, KC, EMC Class A, MSIP Class A, CCC Class A, China RoHS
ENERGY STAR Certified
140 cm
78.4 cm
110.9 cm
114 kg
Shipping Width
150.2 cm
Shipping Depth
78.05 cm
Shipping Height
80.4 cm
Shipping Weight
141 kg
Sound Emission
38 dBA (idle) / 50 dBA (operating)
5 °C
20 - 80%
