Create your own professional-quality colour documents on a compact, easy-to-use, Ethernet-connected laser printer. Print from anywhere with HP ePrint[1]. Save on energy and print black documents affordably[2]
Print professional quality colour documents wirelessly[3].
Print from anywhere in the office and share printing resources on a network, using built-in wireless[3] and 10/100 Ethernet.
Ensure outstanding colour intensity, high gloss and sharp text with HP ImageREt 3600 and Original HP cartridges with ColorSphere toner.
Get excellent print quality automatically on text, images and graphics with HP EasyColor.
Enhance your documents with colour while you keep black printing costs low - get the same black cost per page as from a black-and-white HP LaserJet[2].
Enjoy quick and easy set-up, and print from anywhere[1].
Print from anywhere, anytime, with a smartphone, notebook PC or other mobile device, using HP ePrint[1] and print wirelessly from your iPad®, iPhone® and iPod touch® with AirPrint™[7].
Install and start printing quickly and easily.
Simplify supplies maintenance - order cartridges with HP SureSupply and install them easily[4].
Easily operate and maintain your printer with an easy-to-use, intuitive control panel.
Create and print your own marketing materials.
Estimate print costs with included software, and get project ideas, tools and templates from HP.
Create brochures, postcards and more on a wide range of paper sizes, from 7.6 x 12.7 cm to 21.5 x 35.5 cm.
Achieve great results: pre-configured shortcuts optimise output quality based on the media selected.
Easily adjust spot colours and apply them throughout a document with basic colour-match settings.
Reduce your environmental impact.
Save energy, plus start and finish your print job faster with Instant-on Technology[8].
Reduce packaging waste and save space with the compact size of this colour laser printer.
Get easy recycling - cartridges returned through HP Planet Partners are recycled responsibly[5].
Print only the web content you need, neatly and accurately, with HP Smart Web Printing[6].
[1] May require an Internet connection to the printer. Feature works with any Internet- and e-mail-capable device and requires a firmware upgrade. For details, ww.hp.com/go/ePrintCenter.
[2] Compared with HP LaserJet Pro P1566/ P1606dn printer. Assuming customer is printing at least 30 percent of total pages in colour with content similar to the colour ISO/IEC 19798 test suite (www.iso.org/jtc1/sc28) and overall average job length of three pages. Yields established using ISO/IEC test standards. Actual yields and costs vary considerably depending on images printed, number of colour pages printed, and other factors.
[3] Built-in wireless is available on the HP LaserJet Pro CP1525nw only. Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections.
[4] Programme features and availability may vary by country. For more information, visit www.hp.com/learn/suresupply.
[5] Programme availability varies. HP print cartridge return and recycling is currently available in more than 49 countries, territories and regions in Asia, Europe, and North and South America through the HP Planet Partners programme. For more information, visit www.hp.com/recycle.
[6] To use this feature, you need Microsoft Internet Explorer 6.0 or higher.
[7] Supports iOS 4.2 devices (iPad, iPhone 4, iPhone 3GS, and 3rd and 4th generation iPod touch) that support multitasking. Works with HP ePrint-enabled printers and all-in-ones. AirPrint and iOS 4.2 devices require an 802.11 wireless network connection to the printer. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint and the AirPrint Logo are trademarks of Apple Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
[8] Compared with traditional fusing
Get professional color documents - wirelessly
With HP Color LaserJet Pro CP1525n, you can print from anywhere in the office with wireless. Share printing resources using built-in Ethernet. Get excellent print quality automatically on text, images and graphics. Enhance your documents with color while you keep black printing costs low - get the same black cost per page as from a black-and-white HP LaserJet. -
With HP Color LaserJet Pro CP1525n, you can print from anywhere, anytime, with a smartphone, notebook PC or other mobile device. And install and start printing quickly and easily. It simplify supplies maintenance - order cartridges and install them easily, you can easily operate and maintain your printer with an easy-to-use, intuitive control panel. -
With HP Color LaserJet Pro CP1525n, you can achieve great results - pre-configured shortcuts optimize output quality based on the media selected. Easily adjust spot colors and apply them throughout a document with basic color-match settings. -
HP Color LaserJet Pro CP1525n can save energy, plus start and finish your print job faster. With this laser printer, you can reduce packaging waste and save space, get easy recycling, print only the web content you need, neatly and accurately.
- HP Color LaserJet Pro CP1525n - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 18.1 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Max Media Size (Standard)
- Legal, A4
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 12 ppm - black normal - A4 (210 x 297 mm) , Up to 8 ppm - colour normal - A4 (210 x 297 mm)
- Max Resolution ( B&W )
- 600 dpi
- Max Resolution ( Colour )
- 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Interface
- USB, LAN
- Processor
- 600 MHz
- RAM Installed ( Max )
- 128 MB ( 384 MB ) - DDR2 SDRAM - SO DIMM 144-PIN
- Language Simulation
- PCL 5E, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, glossy paper, cards, bond paper, recycled paper
- Total Media Capacity
- 150 sheets
- Media Handling
- Priority feed tray, 150-sheet input tray
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- Power
- AC 230V
- System Requirements
- Microsoft Windows 7, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.5.8
- Microsoft Certification
- Compatible with Windows 7
- 39.9 cm x 45.3 cm x 25.4 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 600 dpi
- 600 dpi
- HP ImageREt 3600
- Fonts Included
- 49 x TrueType , 35 x PostScript
- Media Handling
- Processor
- 600 MHz
RAM
- 128 MB / 384 MB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Weight
- 60 g/m2 - 220 g/m2
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 125 sheets
Duty Cycle
- 30000 pages
- 250 - 1000 pages
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge ( black ) - up to 750 pages , 1 x toner cartridge ( cyan ) - up to 750 pages , 1 x toner cartridge ( magenta ) - up to 750 pages , 1 x toner cartridge ( yellow ) - up to 750 pages
- EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50 Hz
- 295 Watt
- Power Consumption Stand by / Sleep
- 12.5 Watt
- Software Included
- HP Smart Web Printing, HP ePrint
- OS Required
Environmental Standards
- ENERGY STAR
- 15 °C
- 33 °C
- 10 - 80%
- Sound Emission (Operating)
- 48 dBA
- 39.9 cm
- 45.3 cm
- 25.4 cm
- 18.1 kg
- Width (Shipping)
- 50 cm
- Depth (Shipping)
- 33.3 cm
- Height (Shipping)
- 55 cm
- Weight (Shipping)
- 22.3 kg
Ink (5)
| HP Office Paper - Plain paper - A4 (210 x 297 mm) - 500 sheet(s) - 80 g/m2 | Out of Stock | £6.66 |
| HP 128A Black Cart | In Stock | £49.10 |
| HP 128A Cyan Print Cart | In Stock | £46.86 |
| HP 128A Magenta Print Cart | In Stock | £46.85 |
| HP 128A Yellow Cart | In Stock | £46.86 |
