HP Color LaserJet Enterprise M553dn
Quicklinx: B9YPWS00 Mfr#: B5L25A#B19
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Speed and colour are the perfect pair for your business. That's why this energy-efficient printer and Original HP Toner cartridges with JetIntelligence combine to produce vibrant, professional-quality documents right when employees need them.
  • Enjoy high-speed performance, right when you need it
    Print from sleep mode in as fast as 9 seconds. Get two-sided prints as quickly as one – up to 40 ipm.This printer uses exceptionally low amounts of energy – thanks to smart media-sensing and toner technology.Manage jobs and settings quickly with the 4-line colour display and use the 10-key pad for PIN printing.Consistently print high-quality documents across a variety of media – including A5 – with automatic media sensing.
  • Keep your printer fleet simple, protected and streamlined
    Centralise control of your print environment with HP Web Jetadmin – and help build business efficiency.Protect sensitive data with embedded or optional features, including HP JetAdvantage Security Solutions.Easily develop, deploy and add on HP and third-party solutions. Choose the optional 1 GB memory upgrade.Increase security, restore control and help avoid additional expenses with HP JetAdvantage Private Print.
  • Print whenever business demands
    Easily print from a variety of smartphones and tablets – generally no setup or apps required.Print with just a touch of your NFC-enabled mobile device to this printer – no network needed.
  • Get more pages, performance and protection
    Original HP Toner cartridges with JetIntelligence deliver more pages per cartridge than predecessors.Count on professional quality at fast speeds – HP ColorSphere 3 toner works best with your HP printer.Help ensure the authentic HP quality you paid for with anti-fraud and cartridge authentication technology.Print right away with preinstalled cartridges. Replace them with optional high-yield cartridges.
HP Color LaserJet Enterprise M553dn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
27.5 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 40 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 38 ppm - colour - A4 (210 x 297 mm) , Up to 40 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 38 ipm - colour duplex - A4 (210 x 297 mm) , Up to 40 ipm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 59 ppm - B/W - A5 (148 x 210 mm) , Up to 59 ppm - colour - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
1.2 GHz
RAM Installed (Max)
1 GB (2 GB) - DDR3 SDRAM - DIMM 90-pin
Flash Memory Installed (Max)
4 GB
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, heavy-weight glossy paper, bond paper, recycled paper, opaque film, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 - 6000 pages
Print server
Printer Features
Hardware integration pocket, Instant-on Technology
UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x
45.8 cm x 47.9 cm x 39.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
HP ImageREt 3600
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6 sec
First Print Out Time Colour
7 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
1 GB / 2 GB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Flash Memory
Flash Memory
4 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
Media Weight
60 g/m² - 220 g/m²
650 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - 216 x 297 mm weight: 60 g/m² - 220 g/m²
Max Media Capacity
2300 sheets
Output Trays Capacity
250 sheets
Duty Cycle
80000 pages
2000 - 6000 pages
Print server
Network Controller Name
HP Jetdirect
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP
Security Protocols & Features
Kerberos, LDAP, Apple Bonjour, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 5000 pages ISO/IEC 19798
FCC Class A certified, CISPR 22 Class A, Laser Class 1, FCC CFR47 Part 15, IEC 60825-1, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, EN 62479:2010, IEC 60950-1:2005, EN 55024:2010, EN 55022:2010 Class A, ICES-003 issue 5 Class A
Power supply - internal
Frequency Required
50 Hz
624 Watt
Power Consumption Stand by
33.6 Watt
Power Consumption Sleep
3.95 Watt
Software Included
Drivers & Utilities
Environmental Standards
Blue Angel
ENERGY STAR
15 °C
30 °C
10 - 80%
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
51 dBA
45.8 cm
47.9 cm
39.9 cm
27.5 kg
Width (Shipping)
60 cm
Depth (Shipping)
59.8 cm
Height (Shipping)
50 cm
Weight (Shipping)
31.3 kg
Ink (10)
B9YP HP 508A Black Original Toner Cartridge In Stock £135.74
B9YP HP 508A Cyan Original Toner Cartridge In Stock £170.20
B9YP HP 508A Yellow Original Toner Cartridge In Stock £170.20
B9YP HP 508A Magenta Original Toner Cartridge In Stock £170.20
B9YP HP 508X High Yield Black Original Toner Cartridge In Stock £189.78
B9YP HP 508X High Yield Cyan Original Toner Cartridge In Stock £262.72
B9YP HP 508X High Yield Yellow Original Toner Cartridge In Stock £262.72
B9YP HP 508X High Yield Magenta Original Toner Cartridge In Stock £262.72
B9YP HP M522 Laserjet Toner Collection Unit In Stock £17.89
B9YP HP M522 220V Fuser Unit In Stock £177.48
Other bundles (3)
B9YP HP Care Pack Next Business Day Hardware Support with Defective Media Retention 3 Years On-Site In Stock £171.59
B9YP HP Media tray - 550 sheets - for M552dn, M553dn, M553n, M553x In Stock £203.27
B9YP HP Color LaserJet Printer Cabinet For Color LaserJet Enterprise In Stock £207.89
