Aruba HP 5400R 1100W POE+ ZL2 Power Supply
Quicklinx: BQJNWS00 Mfr#: J9829A
Standard PoE+ power supply for 5400R zl2 switch series, providing up to 1,100 watts.
HPE Aruba - power supply - 1100 Watt
Power supply - plug-in module
2.74 kg
Power Capacity
1100 Watt
18.92 cm x 15.87 cm x 12.95 cm
HPE Aruba 5406R 8-port 1/2.5/5/10GBASE-T PoE+ / 8-port SFP+ (No PSU) v3 zl2, 5406R-44G-PoE+/2SFP+ v2 zl2, 5406R-44G-PoE+/4SFP v2 zl2, 5412R 92GT PoE+ / 4SFP+ (No PSU) v3 zl2, 5412R-92G-PoE+/2SFP+ (No PSU) v2 zl2, 5412R-92G-PoE+/2SFP+ v2 zl2 (1100 Watt), 5412R-92G-PoE+/4SFP v2 zl2 (1100 Watt)
Power Capacity
1100 Watt
18.92 cm
15.87 cm
12.95 cm
2.74 kg
HPE Aruba 5406R 8-port 1/2.5/5/10GBASE-T PoE+ / 8-port SFP+ (No PSU) v3 zl2 (1100 Watt), 5406R-44G-PoE+/2SFP+ v2 zl2 (1100 Watt), 5406R-44G-PoE+/4SFP v2 zl2 (1100 Watt), 5412R 92GT PoE+ / 4SFP+ (No PSU) v3 zl2 (1100 Watt), 5412R-92G-PoE+/2SFP+ (No PSU) v2 zl2 (1100 Watt), 5412R-92G-PoE+/2SFP+ v2 zl2 (1100 Watt), 5412R-92G-PoE+/4SFP v2 zl2 (1100 Watt)
