Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
Designed and Engineered to Provide Reliable and Cost Efficient Data Storage
The HPE Server SATA Hard Drives increase reliability and lower start-up costs without sacrificing reliability with non-mission critical hard drives at the lowest $/GB.Both cost and capacity optimized solutions provide up to 10 TB of storage in a single device. Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) that are available in a wide variety of capacity points.Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.6 Gb/sec data transfer rate supporting existing servers.
- HPE Midline - hard drive - 500 GB - SATA 3Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Spindle Speed
- 7200 rpm
- 1-year warranty
- Designed For
- ProLiant DL120 G5 (3.5"), DL120 G6 (3.5"), DL160 G5 (3.5"), DL160 G5p (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G5 (3.5"), DL165 G5 Special Server (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry, MicroServer (3.5"), ML10 Entry (3.5"), ML10 Special (3.5"), ML110 G5 (3.5"), ML110 G6, ML110 G7 (3.5"), ML110 G7 Base (3.5"), ML110 G7 Entry (3.5"), ML115 G5 (3.5"), ML115 G5 Special Server (3.5"), ML150 G5 (3.5"), ML150 G6 (3.5"), ML150 G6 Entry (3.5"), ML330 G6 (3.5"), ML330 G6 Entry (3.5")
- Capacity
- 500 GB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 3Gb/s
Performance
- Drive Transfer Rate
- 300 MBps (external)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 3 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Limited warranty - parts and labour - 1 year
- Designed For
- HPE ProLiant DL120 G5 (3.5"), DL120 G6 (3.5"), DL160 G5 (3.5"), DL160 G5p (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G5 (3.5"), DL165 G5 Special Server (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry, MicroServer (3.5"), ML10 Entry (3.5"), ML10 Special (3.5"), ML110 G5 (3.5"), ML110 G6, ML110 G7 (3.5"), ML110 G7 Base (3.5"), ML110 G7 Entry (3.5"), ML115 G5 (3.5"), ML115 G5 Special Server (3.5"), ML150 G5 (3.5"), ML150 G6 (3.5"), ML150 G6 Entry (3.5"), ML330 G6 (3.5"), ML330 G6 Entry (3.5")
