HPE 500GB hot-swap SATA 7200RPM
Quicklinx: 72DHWS00 Mfr#: 459319-001
HPE 500GB hard drive - hot-swap. 3.5" form factor. Interface- Serial ATA-300.
HPE - hard drive - 500 GB - SATA 3Gb/s
Hard drive - hot-swap
500 GB
3.5"
SATA 3Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
ProLiant DL160 G5, DL160 G5p, DL165 G5, DL165 G5p, DL180 G5, DL185 G5, DL320 G5p, DL320s, DL385 G5p, ML150 G5, ML310 G5, ML310 G5p, ML350 G5; StorageWorks All-in-One Storage System 1200r 12TB, 1200r 3TB, 1200r 6TB, 1200r 9TB; StorageWorks Modular Smart Array 20, 60
500 GB
3.5"
SATA 3Gb/s
Performance
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
HPE ProLiant DL160 G5, DL160 G5p, DL165 G5, DL165 G5 Special Server, DL165 G5p Base, DL165 G5p Performance, DL180 G5, DL180 G5 Special Server, DL185 G5, DL185 G5 12TB SATA Storage Server, DL185 G5 4TB SATA Storage Server, DL185 G5 6TB SATA Storage Server, DL185 G5 9TB SATA Storage Server, DL185 G5 Base SATA Storage Server, DL185 G5 Special Server, DL320 G5p, DL320s, DL385 G5p Base (3.5"), DL385 G5p High Performance (3.5"), ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML310 G5, ML310 G5p, ML350 G5 (3.5"), ML350 G5 Entry , HPE StorageWorks All-in-One Storage System 1200r 12TB SATA Model, 1200r 3TB SATA Model, 1200r 6TB SATA Model, 1200r 9TB SATA Model , HPE StorageWorks Modular Smart Array 20, 20 Starter kit, 60, 60 Starter Kit
