Your basket is empty
HP 2GB Dual Rank x8 PC3-10600
Quicklinx: 5LCHWS00 Mfr#: 500656-B21
£60.01 ex VAT
£72.01 inc VAT
Marketing description is not available.
HP memory - 2 GB - DIMM 240-pin - DDR3
Storage Capacity
2 GB
Upgrade Type
System specific
DDR3 SDRAM
DIMM 240-pin
Memory Speed
1333 MHz ( PC3-10600 )
Data Integrity Check
ECC
Latency Timings
CL9
Dual rank , registered
ProLiant BL2x220c G7, BL460c G7, BL490c G7, BL620C G7, BL680c G7, DL360 G7, DL370 G6, DL380 G7, DL580 G7, DL980 G7, SL160s G6, SL170s G6, SL390s G7; StorageWorks X1400 G2, X1500 G2, X1600, X1600 G2, X1800, X1800 G2, X3400 G2, X3800 G2, X3800sb G2; StorageWorks Network Storage Blade X1800sb G2
Storage Capacity
2 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Memory Speed
Latency Timings
CL9
ECC
RAM Features
Compatible Slots
1 x memory - DIMM 240-pin
HP ProLiant BL280c G6, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL2x220c G7, BL460c G6, BL460c G7, BL490c G6, BL490c G7, BL620C G7, BL680c G7, DL120 G6, DL120 G6 Performance, DL160 G6, DL160se G6, DL180 G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Entry, DL360 G7 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL980 G7, ML150 G6, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL170s G6 1U Left Half Width tray, SL170s G6 1U Right Half Width tray, SL170s G6 Base 1U Left Half Width tray, SL170s G6 Base 1U Right Half Width tray, SL170s G6 Entry 1U Left Half Width tray, SL170s G6 Entry 1U Right Half Width tray, SL170s G6 Performance 1U Left Half Width tray, SL170s G6 Performance 1U Right Half Width tray, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6 Workstation Blade , HP StorageWorks Network Storage Blade X1800sb, X1800sb G2 , HP StorageWorks Network Storage Gateway X3400, X3400 G2, X3800, X3800 G2, X3800sb, X3800sb G2 , HP StorageWorks Network Storage System X1400 2TB SATA Model, X1400 4TB SATA Model, X1400 G2, X1500 G2, X1600, X1600 12TB SATA Model, X1600 292GB SAS Model, X1600 5.4TB SAS Model, X1600 6TB SATA Model, X1600 G2, X1800, X1800 2.4TB SAS Model, X1800 292GB SAS Model, X1800 3.6TB SAS Model, X1800 6TB SATA Model, X1800 G2, X3410, X3420, X3820
Resources
The following resources are available for the HP 2GB Dual Rank x8 PC3-10600
Accessory Type: Memory
Brand: HP
Price Range Ex VAT: 50 - 100
