HPE HP 2620-24 24-Port Switch
Quicklinx: 7WQWWS00 Mfr#: J9623A
The HPE 2620 Switch Series provides cost-effectiveness, flexibility, and ease of use for enterprise edge, SMB, and branch office access layer deployments. This Fast Ethernet switch has a robust Basic Layer 3 feature set with static and RIP routing, PoE+, ACLs, sFlow, IPv6, and requires no software licensing. The HPE 2620 Switch Series is easy to use and deploy, and delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management.
  • Flexible, Simple and Cost-effective Fast Ethernet Switches
    The Aruba 2620 Switch Series provides cost-effectiveness, flexibility, and ease of use for enterprise edge, SMB, and branch office access layer deployments.Cost-effective Fast Ethernet switch with four Gigabit Ethernet uplinks (two copper and two SFP) and support for external and redundant power supplies for improved network resiliency and quickly scaling of PoE+ devices.Robust Basic Layer 3 feature set includes static and RIP routing, PoE+, ACLs, sFlow, IPv6, and requires no software licensing.
  • Power at the Edge
    The Aruba 2620 Switch Series is designed with up to 370 W of internal PoE+ power and easily scales to 740 Watts with simple connection to EPS/RPS. A model with 128 W is ideal when you only need to power several PoE+ devices.Optional redundant power with external RPS/EPS enhances network resiliency. Highly rated, 80 PLUS Silver Grade Power Supplies on the 2620-24-PoE+ and 2620-48-PoE+ switches conserve energy resources.Increase performance with selectable queue configurations and associated memory buffering that meet your network application performance requirements.
  • Security and Quality of Service (QoS) You Can Rely on
    The Aruba 2620 Switch Series includes security and (QoS) features to build a network that meets ever-changing corporate policies and compliances and helps protect your data from both inside and outside attacks.The Aruba 2620 Switch Series supports flexible authentication options include standards based security protocols such Local MAC, 802.1X, and MAC and Web for greater, policy-driven application security.Traffic prioritization (IEEE 802.1p) allows real-time traffic classification into eight priority levels that are mapped to eight queues.Powerful multilevel-access security controls include source-port filtering, RADIUS/TACACS+, SSL, Port Security, and MAC address lockout.Defend your IPv6 network with DHCPv6 Protection.
  • Single View of the Network
    The Aruba 2620 Switch Series supports Aruba ClearPass Policy Manager for unified and consistent policy between wired and wireless users and simplifies implementation and management of guest login, user onboarding, network access, security, QoS, and other network policies.Supports Aruba Airwave to provide common platform for Zero-Touch Provisioning management, and monitoring for wired and wireless network devices.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms, and events.TR-069 delivers zero touch deployment for devices with dynamic IP addresses and on private networks.
HPE Aruba 2620-24 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L4 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x 10/100/1000 + 2 x SFP
Performance
Routing/switching capacity: 12.8 Gbps , Throughput: up to 9.5 Mpps
MAC Address Table Size
16000 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
RIP-1, RIP-2, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 2, RMON, Telnet, SNMP 3, SNMP 2c, HTTPS, TFTP, SMON
Flow control, auto-sensing per device, DHCP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, IPv6 support, half duplex mode, full duplex mode, sFlow, MSTP support, ACL support, QoS, Jumbo Frames support, MLD snooping, STP Root Guard, LLDP support, MAC address lockout, dynamic ARP protection, DHCP protection, per-port broadcast throttling
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
44.3 cm x 25.4 cm x 4.4 cm
2.6 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
Performance
16000 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Freescale MPC8313: 400 MHz
RAM
512 MB
Flash Memory
512 MB
24 x 10Base-T/100Base-TX - RJ-45 , 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x console RJ-45 management
External power adapter
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950, EN 60825
44.3 cm
25.4 cm
4.4 cm
2.6 kg
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
7WQW C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
