The HP 1810 Switch Series, part of the HP OfficeConnect portfolio, are designed for small businesses looking for key features in an easy-to-administer solution. These devices are smart-managed, fixed-configuration, Gigabit Ethernet and Fast Ethernet Layer 2 switches and include 8- and 24-port models and a 48-port Gigabit Ethernet model. Both the 8- and 24-port HP 1810 Switch Series include the latest energy-saving capabilities, including Energy Efficient Ethernet (EEE) and idle-port power down. These models are also fanless making them ideal for office deployments.
- HPE 1810-8G v2 Switch - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Throughput: up to 11.9 Mpps , Switching capacity: 16 Gbps
- MAC Address Table Size
- 8000 entries
- Jumbo Frame Support
- 9220 bytes
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTPS
- Flow control, full duplex capability, Layer 2 switching, DHCP support, PoE, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, port mirroring, SNTP support, STP support, RSTP support, QoS, LLDP support, packet storm protection
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 20.14 cm x 11.81 cm x 4.39 cm
- 380 g
- Enclosure Type
- Desktop, wall-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- 8000 entries
- 9220 bytes
- Encryption Algorithm
- SSL
- RAM
- 128 MB
- Flash Memory
- 8 MB
- 8 x 1000Base-T RJ-45
- Voltage Required
- FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC 60950, EN55022 Class A, RoHS, UL 60950-1, WEEE, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-4
- 20.14 cm
- 11.81 cm
- 4.39 cm
- 380 g
- 0 °C
- 40 °C
- 15 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 15 - 95%
