Hitachi education projectors bring together innovative features for superior picture quality. Motion Adaptive Progressive Scan reduces line flicker, boosting resolution and smoothing moving images. Noise Reduction boosts clarity. And Hitachi's unique Equalizing Gamma Function helps you customise gamma and color balance to suit your preferences.
Saver Mode
The Saver Mode reduces lamp power by 70% compared to Normal Mode, resulting in considerable energy savings. You can set the time for Saver Mode from 1 to 30 minutes. If the projected image does not change within the set time, the Saver Mode is activated. -
Intelligent Eco Mode
When Intelligent Eco Mode is selected, the lamp power adjusts according to screen brightness. Lamp power decreases when the image is dark and increases when the image is bright. Using Intelligent Eco Mode increases the contrast ratio of the projector while decreasing the use of electricity. -
High picture quality
Hitachi education projectors bring together innovative features for superior picture quality. Motion Adaptive Progressive Scan reduces line flicker, boosting resolution and smoothing moving images. Noise Reduction boosts clarity. And Hitachi's unique Equalizing Gamma Function helps you customise gamma and color balance to suit your preferences. -
Blackboard and whiteboard modes
Projecting onto colored backgrounds can make images appear dull - shiny backgrounds can make them uncomfortably bright. With these blackboard and whiteboard modes, you can ensure optimal brightness whether the screen is black, green or shiny white.
- Hitachi CP-EX301N - 3LCD projector
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness (White)
- 3000 lumens
- Brightness (Colour)
- 2460 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 16.7 million colours
- Bulb type
- 225 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43)
- Video Modes
- 480p, 480i, 525i, 525p, 625i, 576i, 1080/60i, 720/60p, 1080/50i, 720/50p, 750p, 1080/50p, 1080/60p, 1125i, 1125p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 32 cm x 24.5 cm x 8.5 cm
- 3 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- 3000 lumens
- 2460 lumens
- Brightness (Reduced)
- 2460 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.91 m - 10.9 m
- Throw Ratio
- 1.5 - 1.8:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- 225 Watt
- Bulb life cycle
- Controls & Adjustments
- Gamma correction, colour temperature, keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Croatian, Slovenian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Latvian, Lithuanian, Estonian, Romanian, Japanese, Korean, Persian
- Eco-Mode technology, freeze frame, Blackboard Mode, integrated de-interlacer (progressive scan), Closed Caption, High-bandwidth Digital Content Protection System (HDCP), Noise Reduction, Greenboard Mode, 3LCD Technology, 3:2 pull down compensation, Whiteboard Mode, input source naming, PJlink, Crestron RoomView, Template Function, Direct Power On, blank screen, ImageCare Technology, MyScreen, Auto Power Off
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x HDMI - 19 pin HDMI Type A , 2 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA input / output - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-out - RCA x 2 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type B
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, PIN code, security bar, My Screen lock, keypad lock
- Plug and Play, cUL, DDC-2B, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, C-Tick Class B, FCC Part 15 B, RoHS, UL 60950-1, EN 60950-1, WEEE, ErP Ready
- Power Source
- AC
- Voltage Required
- Power Consumption Stand by
- 0.5 Watt
- 32 cm
- 24.5 cm
- 8.5 cm
- 3 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 32 dB
