HGST 1TB Travelstar 7K1000 SATA 6GB/s 9.5mm 32MB 7200RPM 2.5" Hard Drive
Quicklinx: 9J1ZWS00 Mfr#: 0J22423
Travelstar 7K1000 is the industry's only seventh-generation 7200 RPM mobile hard drive and ideally suited for notebook PC upgrades and portable, high-capacity personal storage products. At 500 GB/platter, this 2.5-inch hard drive offers a large capacity and leverages advanced format, which increased the physical sector size from 512 bytes to 4,096 (4K) bytes to improve drive capacities and error correction capabilities.
The Travelstar 7K1000 allows manufacturers to deliver high-capacity, power-efficient systems with desktop-like performance. Manufacturers can consult the HGST advanced format technology brief for more information on using these hard drives. The 7K1000continues HGST's tradition of ecological leadership and carries its EcoTrac classification. Travelstar 7K1000 delivers speed and capacity, without sacrificing battery life or audio quality, to meet the multi-tasking demands of commercial and consumer users on the go.
WD Travelstar 7K1000 HTS721010A9E630 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
TrueTrack servo technology, Thermal Flyheight Control (TFC), Advanced Format technology
70 mm x 100 mm x 9.5 mm
115 g
Microsoft Certification
Compatible with Windows 7
1 TB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
32 MB
Bytes per Sector
512
70 mm
100 mm
9.5 mm
115 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
161 MBps
Seek Time
12 ms (average) / 20 ms (max)
Track-to-Track Seek Time
1 ms
Average Latency
4.2 ms
Spindle Speed
7200 rpm
Reliability
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Power Consumption
5.5 Watt (active) , 0.2 Watt (idle)
Halogen-free
60 °C
Shock Tolerance
225 g @ 1ms half-sine pulse (operating) / 1000 g @ 1ms half-sine pulse (non-operating)
