HannsG HE195ANB 18.5" 1366x768 5ms VGA Monitor
Quicklinx: BDZ5WS00 Mfr#: HE195ANB
Marketing description is not available.
HANNS.G HE195ANB - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Energy Class
Class D
Power Consumption (On mode)
11 W
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 40000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
44.4 cm x 18.5 cm x 32.9 cm
2.56 kg
Environmental Standards
ENERGY STAR Qualified
UL, BSMI, GOST, cUL, CB, FCC, China Energy Label Level 1
Display Type
Energy Class
Class D
Diagonal Size
18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 61 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
WLED
2.56 kg
VGA
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.5 m
Input Voltage
11 W
11 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.5 Watt
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 85% (non-condensing)
BDZ5 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
BDZ5 StarTech.com Articulating Monitor Arm In Stock £132.69
BDZ5 StarTech.com Dual Monitor Stand In Stock £91.00
BDZ5 StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
