Gigabyte Z97P-D3 S1150 Intel Z97 4xDDR3 4xUSB3.0 10xUSB2.0 GBE ATX
Quicklinx: 9FWXWS00 Mfr#: GA-Z97P-D3
GA-Z97P-D3 Intel® Z97 Chipset
  • Supports 4th and 5th Generation Intel® Core™ processors
  • Extreme multi graphics support
  • HD Audio support
  • LAN with high ESD Protection
  • GIGABYTE LAN Optimizer
  • Long lifespan Durable Solid caps
  • Supports HDMI output
  • APP Center including EasyTune™ and Cloud Station™ utilities
  • GIGABYTE UEFI DualBIOS™
  • LAN optimizer - intelligent optimization network management tool
    GIGABYTE LAN optimizer is designed to allow the user to manage different types of network traffic so that data streams such as HD media, web browsing or online gaming can be prioritized, taking precedence over large data downloads that tend to strangle overall network bandwidth.
  • All solid caps and low RDS (on) MOSFETs
    GIGABYTE uses all solid caps and low RDS (on) MOSFETs which are rated to work at higher temperatures to provide a longer lifespan.
  • 5x gold plated CPU socket design
    GIGABYTE 9 series motherboards come equipped with a gold plated CPU socket, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins and bad contacts.
  • ESD protection for USB and LAN
    GIGABYTE 9 series motherboards raise the bar in terms of protecting your system, providing advanced electrostatic discharge (ESD) protection for both your Ethernet LAN and USB ports, both common sources of ESD-related failures. Each LAN and USB port is paired with a dedicated protection filter that can withstand high electrostatic discharges, protecting your system from common electrical surges and even direct lighting strikes.
  • Power failure protection with anti-surge IC
    GIGABYTE 9 series Ultra Durable motherboards also feature special anti-surge ICs that protect your motherboard, and your PC from any surge in power delivery that may occur, helping to ensure that your PC is equipped to deal with any potentially irregular and inconsistent power delivery.
  • Humidity protection with Glass Fabric PCB
    There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. GIGABYTE 9 series motherboards have been designed to make sure that humidity is never an issue, incorporating a Glass Fabric PCB technology that repels moisture caused by humid and damp conditions.
  • 4K Ultra HD support
    4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated Intel HD graphics via HDMI.
  • HDMI - the next generation multimedia interface
    HDMI is a high-definition multimedia interface which provides up to 5 Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion.
Gigabyte GA-Z97P-D3 - 1.0 - motherboard - ATX - LGA1150 Socket - Z97
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2500 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 3000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
4 x DIMM 240-pin , 1 x CPU , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard , 1 x HDMI , 1 x PS/2 mouse , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
Q-Flash, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, Ultra Durable, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, GIGABYTE LAN Optimizer, ESD Protection, Clear CMOS Button, GIGABYTE Smart Switch
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Fast Boot
Plug and Play, ACPI 5.0
30.5 cm
20 cm
