The GA-9SISL delivers advanced performance on a platform including all the features required to be an optimal choice for light and scalable server applications. In addition to the excellent computing power and energy consumption ratio the GA-9SISL features DIMM and PCIe slots for additional storage or network features Gigabit LAN ports for flexible network configurations as well as board placement, optimized for rackmount integration. This combination of features makes the GA-9SISL a great solution to build microservers, lightweight redundant configurations, web hosting arrays, network appliances and much more.
- Gigabyte GA-9SISL - 1.0 - motherboard - mini ITX - Intel Atom C2750
- Product Type
- Motherboard - mini ITX
- Processor
- Intel Atom C2750 / 2.4 GHz (8-core)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
- Storage Ports
- 2 x SATA-600, 4 x SATA-300
- USB / FireWire Ports
- 2 x USB 2.0
- Graphics
- ASPEED AST2400
- LAN
- 4 x Gigabit Ethernet
- Product Type
- Processor
- Cache Memory
- L2 - 4 MB
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Unbuffered
- Single rank, dual rank
Graphics
- Graphics Controller
- ASPEED AST2400
LAN
- Network Interfaces
- Expansion Slots
- 4 x DIMM 240-pin (1.5 V/ 1.35 V) , 1 x PCIe 2.0 x16
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices
- 2 x USB 2.0 , 1 x VGA , 1 x management , 4 x LAN (Gigabit Ethernet) , 1 x serial
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- IPMI 2.0 support
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
- Hardware Features
- Clear CMOS Button
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- 17 cm
- 17 cm
