Measuring merely 17cm in length, the card, specially built for small form factor PCs based on mini-ITX motherboards. Packed with GIGABYTE's unique blade fan design, pure copper heat pipes and patented `Triangle Cool' technology, delivering superior cooling capacity at an extremely low noise level given its compact size.
GIGABYTE Flex display technology(patent-pending) can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
- Powered by NVIDIA GeForce GTX 970 GPU
- Suitable for Mini-ITX/mATX Builds
- Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
- BASE: 1076 MHz / BOOST: 1216 MHz
- Flex Display Technology
- System power supply requirement: 400W (with one 8-pin external power connectors)
Flex Display technology
Gigabyte Flex display technology(patent-pending) can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy. -
Ultra durable VGA
Lower GPU TemperatureUltra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. -
Better overclocking capability
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. -
Decrease power switching loss
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
- Gigabyte GV-N970IXOC-4GD - graphics card - GF GTX 970 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 970
- Memory
- 4 GB GDDR5
- Core Clock
- 1076 MHz
- Boost Clock
- 1216 MHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , DVI-D (dual link) , HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.4, DirectX 12
- 4.3 cm x 18.3 cm x 12.9 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1076 MHz
- Boost Clock
- 1216 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, GIGABYTE Flex Display Technology
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 256-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 8 pin PCI Express power connector
- 4.3 cm
- 18.3 cm
- 12.9 cm
