Compare to reference 6-phase power design, GV-N770OC-4GD V2.0 makes the MOSFET working at a lower temperature and provides more stable voltage output. Besides, over temperature protection and load balance to each MOSFET can effectively extend the card life.
Lower GPU temperature
Ultra durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. -
Better overclocking capability
Ultra durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. -
Decrease power switching loss
Ultra durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. -
8-phase power design
- Gigabyte GV-N770OC-4GD (rev. 2.0) - graphics card - GF GTX 770 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 770
- Memory
- 4 GB GDDR5
- Core Clock
- 1137 MHz
- Boost Clock
- 1189 MHz
- Effective Memory Clock
- 7.01 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- HDMI: 4096 x 2160 / VGA: 2048 x 1536
- Max Monitors Supported
- 4
- DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort
- API Supported
- DirectX 11.1, OpenGL 4.3
- 4.3 cm x 29.2 cm x 12.9 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1137 MHz
- Boost Clock
- 1189 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, Nvidia GeForce 3D Vision Ready, Nvidia PhysX-Ready, GIGABYTE WindForce 3x, Nvidia SLI ready, Triangle Cool Technology, Adaptive V-Sync, NVIDIA GPU Boost, OC Guru II, 8+2 Phase VRM Design
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 600 W
- Additional Requirements
- Two 8-pin power connectors
- Software Included
- OC Guru ll
- 4.3 cm
- 29.2 cm
- 12.9 cm
