GV-N760OC-2GD (rev. 2.0): GIGABYTE Ultra Durable VGA Series
- WINDFORCE 3X Cooling system with Composite Heat-Pipes
- Powered by NVIDIA GeForce GTX 760 GPU
- Integrated with 2GB GDDR5 memory, 256-bit memory interface
- Features Dual-link DVI-I/ DVI-D / HDMI / DisplayPort
- BASE:1085MHz / BOOST:1150 MHz
- System power supply requirement: 500W
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Lower GPU Temperature
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB.
Better Overclocking Capability
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability.
Decrease Power Switching Loss
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Up to 4 displays on a Single Card
In the Kepler architecture, support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
O.C. GURU II
Users can set up monitoring, GPU clock, memory clock, fan, GPU voltage, memory voltage, OSD, online support and update driver, BIOS directly. -
Up to 4 displays on a single card
- Gigabyte GV-N760OC-2GD (rev. 2.0) - graphics card - GF GTX 760 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 760
- Memory
- 2 GB GDDR5
- Core Clock
- 1085 MHz
- Boost Clock
- 1150 MHz
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 4
- DisplayPort , HDMI , DVI-I (dual link) , DVI-D
- API Supported
- DirectX 11.1, OpenGL 4.3
- 4.3 cm x 29.5 cm x 12.9 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1085 MHz
- Boost Clock
- 1150 MHz
- Process Technology
- 28 nm
- Max Resolution
- 2560 x 1600
- 4
- API Supported
- Ultra Durable VGA, GIGABYTE WindForce 3x, OC Guru II
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Software Included
- Drivers & Utilities, OC Guru ll
- 4.3 cm
- 29.5 cm
- 12.9 cm
