Gigabyte introduces Windforce, the latest cooling technology that differentiates the brand's graphics cards from the rest. Gigabyte understands that a fan is crucial to the graphics card, so only the fan with the most efficiency is selected for Windforce.
The airflow is spilt through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card.
Intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
Windforce 2X cooling system
Gigabyte introduces Windforce, the latest cooling technology that differentiates the brand's graphics cards from the rest. Gigabyte understands that a fan is crucial to the graphics card, so only the fan with the most efficiency is selected for Windforce. -
Unique blade fan design
The airflow is spilt through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence. -
Up to 4 displays on a single card
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience. -
Gold plated HDMI x 2
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card. -
OC GURU II
- Gigabyte GV-N75TWF2OC-4GI - OC Edition - graphics card - GF GTX 750 Ti - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti
- Memory
- 4 GB GDDR5
- Core Clock
- 1059 MHz
- Boost Clock
- 1137 MHz
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
- API Supported
- OpenGL 4.4, DirectX 12
- 4.2 cm x 19.7 cm x 12.7 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1059 MHz
- Boost Clock
- 1137 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable 2, GIGABYTE WindForce 2x, Gold plated HDMI, OC Guru II
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 6 pin PCI Express power connector
- Software Included
- OC Guru ll
- 4.2 cm
- 19.7 cm
- 12.7 cm
