GV-N75TOC-2GI
- Ultra Durable 2 Series
- Powered by NVIDIA GeForce GTX 750 Ti GPU
- Integrated with the first 2048MB GDDR5 memory and 128-bit memory interface
- OC Edition - Core Clock: 1033MHz/1111MHz
- Features Dual-link DVI-I / DVI-D / HDMI*2
- Support PCI Express 3.0 x16 bus interface
- System power supply requirement: 400W
Specification
- Chipset GeForce GTX 750 Ti
- Memory Clock 5400 MHz
- Process Technology 28 nm
- Memory Size 2048MB GDDR5
- Memory Bus 128-bit
- Core Clock Base:1033MHz Boost:1111MHz (Standard- Base:1020MHz Boost:1085MHz)
- Card Bus PCI Express 3.0
- DirectX 11.2
- OpenGL 4.4
- PCB Form ATX
- Digital max resolution 4096 X 2160 (via 2 HDMI)
- Analog max resolution 2048 x 1536
- Multi-view 4
- I/O Dual-link DVI-I1/DVI-D1/HDMI*2
- Card size L=204mm , W=144 mm, H=42mm
- Power requirement 400W
Support 4K at 60 Hz via two HDMI
Current graphic cards do not support HDMI specification, it is required to use two HDMI output to support Ultra HD resolution - 4096 x 2160 at 60 Hz. With a monitor features HDMI dual mode, users can experience an impressive 4K HD enjoyment with the latest technological advancements! -
WindForce 2x anti-turbulence-parallel inclined
WindForce 2x parallel-inclined fin design is equipped with 2 ultra quiet PWM fans and copper heat pipe to enlarge air channel on the graphics card vents and creates a more effective airflow system in chassis. -
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. -
Up to 4 displays on a single card
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience. -
OC GURU II
Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
- Gigabyte GV-N75TOC-2GI - graphics card - GF GTX 750 Ti - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti
- Memory
- 2 GB GDDR5
- Core Clock
- 1033 MHz
- Boost Clock
- 1111 MHz
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
- API Supported
- DirectX 11.2, OpenGL 4.4
- 4.2 cm x 20.4 cm x 14.4 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1033 MHz
- Boost Clock
- 1111 MHz
- 28 nm
- Max Resolution
- 4
- API Supported
- Nvidia PhysX-Ready, Ultra Durable 2, Nvidia 3D Vision technology, GIGABYTE WindForce 2x, Gold plated HDMI, Adaptive V-Sync, NVIDIA GPU Boost, OC Guru II
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 400 W
- Software Included
- OC Guru ll
- 4.2 cm
- 20.4 cm
- 14.4 cm
