Gigabyte GeForce GTX 750 Ti 1033MHz 2GB PCI-E 3.0 HDMI OC
Quicklinx: C6G5WS00 Mfr#: GV-N75TOC-2GL#SP
  • NVIDIA GeForce GTX 750 Ti
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
  • Gold plated HDMI
  • Up to 4 displays on a single card
  • OC Guru ll
Gigabyte GV-N75TOC-2GL - graphics card - GF GTX 750 Ti - 2 GB
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1033 MHz
Boost Clock
1111 MHz
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , DisplayPort , 2 x HDMI
API Supported
DirectX 11.2, OpenGL 4.4
4.2 cm x 17.5 cm x 12.1 cm
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1033 MHz
Boost Clock
1111 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Nvidia PhysX-Ready, Ultra Durable 2, Nvidia 3D Vision technology, Gold plated HDMI, Adaptive V-Sync, NVIDIA GPU Boost, OC Guru II
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Required Power Supply
400 W
Low-profile bracket
Software Included
OC Guru ll
4.2 cm
17.5 cm
12.1 cm
