WindForce 2X parallel-inclined fin design is equipped with 2 ultra quiet PWM fans and two copper heat pipes to enlarge air channel on the graphics card vents and creates a more effective airflow system in chassis.
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performance hungry computing applications.
WindForce 2X anti-turbulence-parallel inclined
WindForce 2X parallel-inclined fin design is equipped with 2 ultra quiet PWM fans and two copper heat pipes to enlarge air channel on the graphics card vents and creates a more effective airflow system in chassis. -
PhyX technology
NVIDIA PhysX is the next big thing in gaming! The excellent way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor. -
CUDA technology
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performance hungry computing applications. -
SLI technology
Delivers up to 2x the performance of a single GPU configuration for unparalleled gaming experiences by allowing two graphics cards to run in parallel. The must-have feature for performance PCI Express graphics, SLI dramatically scales performance on 60 top PC games. -
NVIDIA 3D Vision
NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
- Gigabyte GV-N660WF2-2GD (rev. 2.0) - graphics card - GF GTX 660 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 660
- Memory
- 2 GB GDDR5
- Core Clock
- 980 MHz
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- HDMI , DisplayPort , DVI-D , DVI-I (dual link)
- API Supported
- DirectX 11.1, OpenGL 4.3
- 4.2 cm x 25.63 cm x 13.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 980 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 2x, Dual Fan Design, Nvidia SLI ready
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 450 W
- RoHS
- 4.2 cm
- 25.63 cm
- 13.1 cm
