The GIGABYTE custom-designed cooling system features a 90mm fan, 3 pure copper composite heat-pipes, unique blade fan design, heat pipes direct touch technology together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
The composite heat-pipes combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases 29% of cooling capacity.
The GIGABYTE custom-designed cooling system features a 90mm fan, 3 pure copper composite heat-pipes, unique blade fan design, heat pipes direct touch technology together delivering an effective heat dissipation capacity for higher performance at lower temperatures. -
Unique blade fan design
The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans. -
3D Active Fan
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle. -
Composite heat-pipes
The composite heat-pipes combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases 29% of cooling capacity. -
Heat pipe direct touch
The pure copper heat pipes are shaped to maximize the direct contact area to the GPU. -
One-click super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment. -
Ultra durable materials
Engineered with the high-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan. -
Xtreme engine
Adjust clock speeds, voltage, fan performance, power target, OSD setting can be monitored and tuned in real-time according to your own preference through this intuitive interface.
- Gigabyte GeForce GTX 1070 Mini ITX OC - graphics card - GF GTX 1070 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1070
- Memory
- 8 GB GDDR5
- Core Clock
- 1556 MHz
- Boost Clock
- 1746 MHz
- Effective Memory Clock
- 8.008 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DVI-D (dual link) , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.7 cm x 16.9 cm x 13.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1556 MHz
- Boost Clock
- 1746 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- NVIDIA G-Sync ready, NVIDIA GameWorks, GIGABYTE custom-designed 90 mm cooler, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.008 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- XTREME Engine Utility
- 3.7 cm
- 16.9 cm
- 13.1 cm
