Gigabyte GeForce GT 610 810MHz 1GB PCI-Express 3.0 HDMI
Quicklinx: 86HVWS00 Mfr#: GV-N610SL-1GI
  • High-Definition Multimedia Interface (HDMI)
Gigabyte GV N610SL-1GI features gold plated HDMI, gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performances hungry computing applications.
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • Silent cell
    Gigabyte rewrites the history of silent cooling to perfect the thermal performance, introducing the state-of-the-art Silent-Cell Cooling technology which adopts a series of crimping layered fins with aluminum nodes.
  • PhysX technology
    NVIDIA PhysX is the big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor.
  • CUDA technology
  • NVIDIA 3D Vision
    NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
Gigabyte GV-N610SL-1GI - graphics card - GF GT 610 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 610
1 GB DDR3
Core Clock
810 MHz
Effective Memory Clock
1.2 GHz
Shader Clock
1620 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x1536
Max Monitors Supported
2
HDMI , VGA , DVI-I (dual link)
API Supported
DirectX 11, OpenGL 4.2
Fanless
Graphics card - low profile - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
810 MHz
Shader Clock
1620 MHz
Process Technology
40 nm
Max Resolution
2560 x 1600
2
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, GIGABYTE Silent-Cell cooling design, Gold plated HDMI, HDCP
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.2 GHz
Bus Width
64-bit
Required Power Supply
300 W
RoHS
