Gigabyte GV N610SL-1GI features gold plated HDMI, gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performances hungry computing applications.
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. -
Silent cell
Gigabyte rewrites the history of silent cooling to perfect the thermal performance, introducing the state-of-the-art Silent-Cell Cooling technology which adopts a series of crimping layered fins with aluminum nodes. -
PhysX technology
NVIDIA PhysX is the big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor. -
CUDA technology
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performances hungry computing applications. -
NVIDIA 3D Vision
NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
- Gigabyte GV-N610SL-1GI - graphics card - GF GT 610 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 610
- Memory
- 1 GB DDR3
- Core Clock
- 810 MHz
- Effective Memory Clock
- 1.2 GHz
- Shader Clock
- 1620 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x1536
- Max Monitors Supported
- 2
- HDMI , VGA , DVI-I (dual link)
- API Supported
- DirectX 11, OpenGL 4.2
- Fanless
- Graphics card - low profile - fanless
- Bus Type
- Graphics Engine
- Core Clock
- 810 MHz
- Shader Clock
- 1620 MHz
- Process Technology
- 40 nm
- Max Resolution
- 2560 x 1600
- 2
- API Supported
- Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, GIGABYTE Silent-Cell cooling design, Gold plated HDMI, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.2 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- RoHS
