Gigabyte GeForce GT 210 520MHz 1GB PCI-Express 2.0 x16 HDMI
Quicklinx: 8WB7WS00 Mfr#: GV-N210SL-1GI
  • High-Definition Multimedia Interface (HDMI)
Gigabyte GV-N210SL-1GI features NVIDIA CUDA technology. NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programmers to speed up those performance hungry computing applications.
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • CUDA technology
  • PhysX technology
    NVIDIA PhysX is the next big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations.
Gigabyte GV-N210SL-1GI - graphics card - GF 210 - 1 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce 210
1 GB DDR3
Core Clock
520 MHz
Effective Memory Clock
1.2 GHz
Shader Clock
1237 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
2
Interfaces Details
DVI-I (dual link) , VGA , HDMI
API Supported
OpenGL 3.1, DirectX 10.1
Fanless
2.4 cm x 19.7 cm x 12.1 cm
Graphics card - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce 210
Core Clock
520 MHz
Shader Clock
1237 MHz
Max Resolution
2560 x 1600
2
Interfaces Details
API Supported
Nvidia CUDA technology, Nvidia PhysX-Ready, HDCP
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.2 GHz
Bus Width
64-bit
Required Power Supply
300 W
RoHS
2.4 cm
19.7 cm
12.1 cm
