Based on the Silvermot micro-architecture which utilizes the 22 nm process technology, these SoC feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage.
With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
The BRIX is sold as a DIY PC kit, shipping with a NGFF M.2 Wi-Fi module pre-installed, plus a power adapter and cable conforming to local standards. Requiring only system memory and mSATA SSD, the BRIX gives users the flexibility to independently choose integrated storage and system memory size, without the trouble of sourcing components that are not widely available on the retail market.
Intel Celeron processor
Based on the Silvermot micro-architecture which utilizes the 22 nm process technology, these SoC feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage. -
Dual display
With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications. -
Flexible compact PC kit
The BRIX is sold as a DIY PC kit, shipping with a NGFF M.2 Wi-Fi module pre-installed, plus a power adapter and cable conforming to local standards. Requiring only system memory and mSATA SSD, the BRIX gives users the flexibility to independently choose integrated storage and system memory size, without the trouble of sourcing components that are not widely available on the retail market. -
VESA support
Bundled with a VESA bracket, the BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
- Gigabyte BRIX GB-BXCE-3205 (rev. 1.0) - Ultra Compact PC Kit - Celeron 3205U 1.5 GHz - 0 GB - no HDD
- PC barebone - Ultra Compact PC Kit
- Processor
- 1 x Intel Celeron 3205U / 1.5 GHz (Dual-Core)
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics
- Audio Output
- Stereo - integrated
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 10.76 cm x 11.44 cm x 3.39 cm
- PC barebone
- Product Form Factor
Processor / Chipset
- CPU
- Intel Celeron 3205U
- Clock Speed
- 1.5 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Ethernet Controller
- Realtek RTL8111G
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Bluetooth 4.0, IEEE 802.11ac
- Slots
- 1 (total) / 1 (free) x mSATA , 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card
- 4 x USB 3.0 (2 front, 2 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone - mini-jack (1 in front)
- Included Accessories
- VESA wallmount adapter
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 10.76 cm
- 11.44 cm
- 3.39 cm
- 0 °C
- 35 °C
