Redefining the Desktop PC
Challenging the essence of how we define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish design based high polish surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact,versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough (56mm x 107mm x 114mm) to sit in the palm of your hand.
• Features 22nm Intel® Celeron J1900 to deliver to the most intuitive and integrated operating systems in the world
• Supports 2.5" thickness 7.0/9.5mm Hard Drives (1 x 3Gbps)
• Ultra compact PC design – 0.69L(56.1x 107.6 x 114.4mm)
• 1x SO-DIMM DDR3L 1.35V Slots (1333 MHz)
• Preinstall IEEE 802.11 b/g/n Wi-Fi / Bluetooth 4.0 Mini-PCIe card
• Supports dual displays via a VGA and a HDMI port
• Gigabit LAN
• Audio jack (Headphone/MIC)
• VESA mounting bracket (75 x 75mm + 100 x 100mm)
Based on the Silvermot micro-architecture, utilizing the 22nm process technology. The SoCs feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage.
Advanced Features For Power Users
The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it’s designed to deliver the most intuitive and integrated operating systems in the world.
Trouble-Free Setup
The BRIX is packed with wall mount adapter whether undergo rigorous testing for safety and reliability. The BRIX also bundled with a VESA bracket, it can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This offers a simple and elegant way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
Redefining the desktop PC
Challenging the essence of how define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish design based around an anthracite aluminum frame and glass surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough to sit in the palm of your hand. -
Intel Celeron J1900
Based on the silver mot micro-architecture, utilizing the 22 nm process technology, the SoCs feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage. -
Advanced features for power users
The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it's designed to deliver the most intuitive and integrated operating systems in the world. -
Trouble-free setup
- Gigabyte BRIX GB-BXBT-1900 (rev. 1.0) - mini PC - Celeron J1900 2 GHz - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- 1 x Intel Celeron J1900 / 2 GHz (, up to 2.42 GHz, (Quad-Core)
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 0 GB (installed) / 8 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics
- Networking
- GigE, 802.11b/g/n, Bluetooth 4.0
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 10.76 cm x 11.44 cm x 5.61 cm
- PC barebone
- Product Form Factor
- Mini PC
Processor / Chipset
- CPU
- Intel Celeron J1900
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 2.42 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 0 GB / 8 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 1 (Total) / 1 (empty)
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, HDMI
- Ethernet Controller
- Realtek RTL8111G
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x PCIe Half Mini Card , 1 (total) / 1 (free) x SO-DIMM 204-pin
- 1 x USB 3.0 (1 in front) , 1 x HDMI , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x audio line-in/microphone - mini-jack
- Included Accessories
- VESA wallmount adapter
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 10.76 cm
- 11.44 cm
- 5.61 cm
