With three PCI-Express x16 generation 3.0 slots supporting 3-way NVIDIA SLI and AMD CrossFireX modes, this motherboard can receive a trio of GPUs working together to deliver ultra-smooth and accelerated utilization of CAD/CAE and content creation applications. The GA-6PXSV4 can therefore deliver improved workflow, speed-up production, and ultimately strengthen the increasingly pressured capability of design houses to deliver their work in short periods of time.
The GA-6PXSV4 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processor and memory with an ultra-fast response time. Built with advanced calibration tools, they allow to get the purest and most efficient electrical supply to date. When the CPU workload varies in function of the applications running, the Intel Turbo Boost technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPU operations are much more stable, and the overall reliability of the system is greatly improved.
Deploy fleets of remote workstations
Although this model is suitable for tower workstation builds, the placement of its components and its airflow design has been optimized for rack integration. The critical computing resources of CAD/CAE teams within a large organization can be centralized in a way where maintenance and management can be scaled and made more convenient. With a quad LAN solution and a remote management controller, the GA-6PXSV4 is ready for computing intensive applications in virtualized environments. -
3-way GPU support
With three PCI-Express x16 generation 3.0 slots supporting 3-way NVIDIA SLI and AMD CrossFireX modes, this motherboard can receive a trio of GPUs working together to deliver ultra-smooth and accelerated utilization of CAD/CAE and content creation applications. The GA-6PXSV4 can therefore deliver improved workflow, speed-up production, and ultimately strengthen the increasingly pressured capability of design houses to deliver their work in short periods of time. -
Unique memory performance
This board is an extremely high-value building block for memory demanding workstation applications, thanks to its ability to outperform its competitors in memory frequency. Achieved through Gigabyte's capabilities in design, PCB layout and BIOS fine-tuning, this feature will be appreciated in workstation applications where improvements in memory performance results in significant improvements of the user's workflow. -
Digital power control
The GA-6PXSV4 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processor and memory with an ultra-fast response time. Built with advanced calibration tools, they allow to get the pure and efficient electrical supply. When the CPU workload varies in function of the applications running, the Intel Turbo Boost technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPU operations are much more stable, and the overall reliability of the system is greatly improved. -
Support of PCIe generation 3.0
With the support of the PCI Express generation 3.0 technology directly on the CPU, the GA-6PXSV4 is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of expansion cards and graphics cards.
- Gigabyte GA-6PXSV4 - 1.0 - motherboard - ATX - LGA2011 Socket - C604
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C604
- Processor Socket
- 1 x LGA2011 Socket
- Compatible Processors
- Core i7, Xeon E5-1600 series, Xeon E5-2600 series (Maximum TDP 150 Watt)
- Max RAM Size
- 256 GB
- RAM Supported
- 8 DIMM slots - DDR3, ECC, registered, unbuffered
- Storage Ports
- 4 x SAS (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 4 x USB 3.0 + 3 x USB 2.0 + (1 x USB 3.0 + 1 x USB 2.0 via headers)
- Graphics
- ASPEED AST2300
- LAN
- 4 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C604
- Processor Socket
- LGA2011 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 256 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Registered, unbuffered
- Quad channel memory architecture
- Details
- 256 GB - registered - ECC , 64 GB - unbuffered - ECC
Graphics
- Graphics Controller
- ASPEED AST2300
LAN
- Network Controller
- Intel 82574L
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 2.0 x1 , 1 x PCI
- Storage Interfaces
- SAS -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x management , 2 x USB 3.0 , 4 x USB 2.0 , 1 x PS/2 keyboard / mouse
- Internal Interfaces
- 1 x USB 3.0 - header , 1 x USB 2.0 - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- Hardware Features
- NVIDIA 3-way SLI Technology Support, AMD 3-way CrossFireX technology support, Clear CMOS Button
- 30.5 cm
- 24.4 cm
