Gigabyte ATX E3-1200 INTEL4xDIMM 2xGBE
Quicklinx: B9L4WS00 Mfr#: GA-6LXGH
Still based on the 22 nm tri-gate lithography, this generation of Xeon processor is built on Intel's microarchitecture and brings up to 15% computing power improvements and increased L3 cache across the line. In addition, this generation will also bring to the Xeon E3 family the support of 1600 MHz ECC memory, Intel trusted execution and Virtualization technologies, as well as AVX 2.0 and TSX instructions. Last but not least, the Xeon E3-1200 V3 processor will include the Intel integrated graphics, which will bring the support of OGL3.2+, DirectX 11.1, and higher frequencies.
  • Intel Xeon processor E3-1200 V3 product family
  • 10 Gigabit Ethernet LAN onboard
    With virtualized environments getting always more popular and asking for always more resources from the networking side of any system, the GA-6LXGH is ready for high-performance virtual applications thanks to its 10GbE SFP+ controller. Capable of load-balancing, FCoE support, and low latency transfers, this solution allows a simplification of a network's topology while boosting its overall performance.
  • Generation of Dual GbE LAN controller
    With the 3rd iteration of the Intel Xeon processor E3-1200 family also came a generation of dual gigabit LAN controllers. Equipped with an Intel I210 controller, this board is now capable of advanced features such as error correction packet buffers, enhanced management with OS2BMC, MCTP, NC-SI, SMBus, and generally improved transfer performance as well as reduced power consumption.
  • Support of PCIe generation 3.0
    With the support of the PCI Express Gen. 3.0 technology directly on the CPU, the GA-6LXGH is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of its expansion accessories.
Gigabyte GA-6LXGH - 1.0 - motherboard - ATX - LGA1150 Socket - C224
Motherboard - ATX
Chipset Type
Intel C224
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Core i3, Xeon E3-1200 v3 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID), 2 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 3 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Graphics
ASPEED AST2300
LAN
10 Gigabit Ethernet, 2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel C224
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Unbuffered
Single rank, dual rank
Graphics
Graphics Controller
ASPEED AST2300
LAN
Network Interfaces
Expansion Slots
4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x1 , 1 x CPU , 3 x PCI
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
4 x USB 3.0 , 2 x USB 2.0 , 1 x VGA , 1 x PS/2 keyboard / mouse , 1 x LAN (10Gigabit Ethernet) , 2 x LAN (Gigabit Ethernet) , 1 x management
Internal Interfaces
2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x USB 2.0 - Type A , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
IPMI 2.0 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Hardware Features
Clear CMOS Button
I/O back plate
2 x Serial ATA cable
30.5 cm
24.4 cm
