Gigabyte introduces the exclusive "Triangle Cool" technology to reach a better cooling performance. The patented technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" technology provides a more efficient air flow for the cooling system.
Patented "Triangle Cool" technology
Gigabyte introduces the exclusive "Triangle Cool" technology to reach a better cooling performance. The patented technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" technology provides a more efficient air flow for the cooling system. -
OC GURU II
Instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
- Gigabyte GV-R927XOC-4GD - graphics card - Radeon R9 270X - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R9 270X
- Memory
- 4 GB GDDR5
- Core Clock
- 1050 MHz
- Boost Clock
- 1100 MHz
- Effective Memory Clock
- 5.6 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , HDMI , DVI-D (dual link) , DisplayPort
- API Supported
- OpenGL 4.3, DirectX 11.2
- 4.3 cm x 29.7 cm x 13.2 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1050 MHz
- Boost Clock
- 1100 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, GIGABYTE WindForce 3x, AMD App Acceleration, Triangle Cool Technology, Graphics Core Next (GCN), OC Guru II
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.6 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- Two 6-pin power connectors
- Software Included
- AMD Catalyst Control Center, OC Guru ll
- 4.3 cm
- 29.7 cm
- 13.2 cm
