Gigabyte AMD Radeon R5 230 625MHz 1GB PCI-Express 3.0 HDMI LP
Quicklinx: 9M9RWS00 Mfr#: GV-R523D3-1GL
  • High-Definition Multimedia Interface (HDMI)
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. Gigabyte is again setting a new standard by using ferrite core chokes, low RDS (on) MOSFET and lower ESR solid capacitors, providing the stability and reliability from their high-end graphics solution. In addition, Gigabyte Ultra Durable 2 edition graphics card now features a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
  • Ultra Durable 2
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • OC GURU II
    Instinctive user interface, easier to monitoring and adjusting all important settings.
Gigabyte GV-R523D3-1GL (rev. 1.1) - graphics card - Radeon R5 230 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon R5 230
1 GB DDR3
Core Clock
625 MHz
Effective Memory Clock
1.066 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
Interfaces Details
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 11, OpenGL 4.1
2.4 cm x 18.4 cm
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon R5 230
Core Clock
625 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
2
Interfaces Details
API Supported
Ultra Durable 2, AMD HD3D Technology, AMD App Acceleration, Gold plated HDMI, OC Guru II
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.066 GHz
Bus Width
64-bit
Required Power Supply
400 W
Software Included
AMD Catalyst Control Center, OC Guru ll
2.4 cm
18.4 cm
