Gigabyte AMD Radeon 5450 HD 650MHz 1GB PCI-Express 2.1 x16 HDMI
Quicklinx: 8WBMWS00 Mfr#: GV-R545-1GI
  • ATI Radeon HD 5450
  • High-Definition Multimedia Interface (HDMI)
Gigabyte GV R545-1GI features Ultra Durable 2, using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. Gigabyte is again setting a standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, Gigabyte Ultra Durable 2 Edition graphics card now features a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
Avivo could provide vibrant high fidelity, flawlessly smooth next-generation video playback. Avivo technology easily allows your PCs to become digital home media center by its compelling video pipeline design that comprises the latest high definition video hardware acceleration, including H.264 and WMV9.
  • Ultra Durable 2
    Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. Gigabyte is again setting a standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, Gigabyte Ultra Durable 2 Edition graphics card now features a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • Cross Fire
    Multiply and conquer with Multi-GPU performance: CrossFire's "supertiling" GPU sharing speeds rendering by evenly dividing the graphics processing, intelligently alternating the rendering workload to each Radeon GPU for efficient load balancing, and optimized performance. CrossFire boosts image quality along with rendering speed, eliminating the need to crank down screen resolutions to get the high image quality you want.
  • Avivo HD
Gigabyte GV-R545-1GI - graphics card - Radeon HD 5450 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.1 x16
Graphics Engine
ATI Radeon HD 5450
1 GB DDR3
Core Clock
650 MHz
Effective Memory Clock
1.1 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x1536
Max Monitors Supported
2
HDMI , VGA , DVI-I (dual link)
API Supported
DirectX 11, OpenGL 4.1
2.2 cm x 18.3 cm x 12.2 cm
Bus Type
PCI Express 2.1 x16
Graphics Engine
ATI Radeon HD 5450
Core Clock
650 MHz
Process Technology
40 nm
Max Resolution
2560 x 1600
2
API Supported
Avivo HD Technology, ATI CrossFireX Technology, Ultra Durable 2, AMD Eyespeed, Gold plated HDMI
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.1 GHz
Bus Width
64-bit
Required Power Supply
400 W
RoHS
2.2 cm
18.3 cm
12.2 cm
