The easy-to-use N1800 is a network scanner offering cloud linking functions as well as enabling users to email, save and print scanned documents through a network. With an intuitive touchscreen complete with GUI keyboard, the N1800 is efficient, secure and intelligent, thereby minimizing operator involvement before, during and after the scanning process.
The N1800 network imaging scanner is designed to speedily digitize documents and facilitate the paperwork of everyone in the office whether directly into a company's business processes, local network or into the cloud. Directly link the N1800 to a network and digitize documents into processed data for e-mails, faxes, network storage and much more all with remarkable ease in a compact footprint and with intelligent functions to minimize operator involvement.
Whether your documents are monochrome or color, large or small, or a combination of those, just press the Scan button on the N1800 touch panel to convert them into digital data. With the scanner connected to a network, you can directly save and share the digital data through a network resource, including a cloud service such as Google Docs or Salesforce CRM.
Advanced automated functions such as paper size detection, color detection, blank page removal, auto deskew and auto orientation ensure the N1800 digitizes your documents with remarkable precision and efficiency producing flawless scans quickly and without barely lifting a finger.
The N1800 delivers scanning speeds of up to 20 ppm / 40 ipm (color, A4 size at 200 and 300 dpi). Very accurate ultrasonic sensors detect when overlapping pages (multifeed) enter the imaging device. The N1800 features a large, vibrant touch panel, which utilizes 'One Push' interface, so anyone can operate the imaging device with ease.
The N1800 comes armed with advanced security features to ensure safe and secure operation among multiple users, it satisfies the digitizing needs of small networks that use a file server and e-mail server. It's also right at home with more complex LDAP/LDAPS authentication-based networks, integrated with Microsoft Exchange Server, SharePoint and other application hubs.
Collectively monitor and manage scanner usage, setting and much more for multiple N1800 units, through the Scanner Central Admin Server function.
- Fujitsu ScanSnap N1800 - document scanner - desktop - LAN
- Document scanner - desktop
- Interface Type
- LAN
- Scanning Sensor Type
- Dual CCD
- Light Source
- Xe-gas cold cathode fluorescent lamp
- Max Supported Document Size
- 216 x 3024 mm
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 20 ppm (mono) / 20 ppm (colour)
- Max Document Size
- 216 mm x 3024 mm
- Automatic Duplexing
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- 30 cm x 22.6 cm x 17.2 cm
- 6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- LAN
- 216 x 3024 mm
Scanner
- Input Type
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- Max Document Scan Speed B/W
- 20 ppm
- Max Document Scan Speed Colour
- 20 ppm
- Scanner Speed Details
- 20 ppm - black & white - A4 - 200 dpi , 40 ipm - duplex - black & white - A4 - 300 dpi , 20 ppm - colour - A4 - 200 dpi , 40 ipm - duplex - colour - A4 - 300 dpi
- Scanner Features
- 8.4" touch screen TFT display, Ultrasonic multifeed sensor, automatic page size detection
Media Handling
- Max Document Size
- 216 mm x 3024 mm
- Automatic
- 50 sheets
- Supported Protocols
- DHCP, FTP, HTTP, NTP, SMTP, TCP/IP, SMB, LDAP
- LAN
- Cables Included
- 1 x network cable
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 50 Watt (0.5 Watt)
- 30 cm
- 22.6 cm
- 17.2 cm
- 6 kg
- 5 °C
- 35 °C
- 20 - 80%
