Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6670 production level scanner. Designed with outstanding paper handling, high scan speeds up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6670 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6670's intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents, including photos, label stickers, or taped-on receipts. The Fujitsu fi-6670 color scanner comes additionally bundled with PaperStream IP and PaperStream Capture for enhanced batch processing and image enhancement.
True to Fujitsu's commitment to environmentally responsible manufacturing and design, the fi-6670 business scanner adheres to strict environmental regulations including Energy Star's energy consumption requirements and the EU's Reduction of Hazardous Substances and Volatile Organic Compounds.
Intelligent, reliable production scanning for a more productive work environment
Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6670 production scanner. Designed with outstanding paper handling, high scan speeds up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6670 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6670's intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents, including photos, label stickers, or taped-on receipts. -
High-impact imaging solutions, low environmental impact
- Fujitsu fi-6670 - document scanner - desktop - USB 2.0, SCSI
- Document scanner - desktop
- Interface Type
- USB 2.0, SCSI
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- ANSI B (Ledger) (279 x 432 mm)
- Input Type
- Grayscale / Color Depth
- 10-bit grey
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 90 ppm (mono) / 90 ppm (colour)
- Max Document Size
- 279 mm x 432 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 15000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits)
- 30 cm x 17 cm x 30 cm
- 17 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0, SCSI
Scanner
- Input Type
- Grayscale Depth
- 10-bit grey
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- CCD
- Max Document Scan Speed B/W
- 90 ppm
- Max Document Scan Speed Colour
- 90 ppm
- Duty Cycle
- Scanner Speed Details
- 90 ppm - black & white , 90 ppm - colour , 180 ipm - duplex - black & white , 180 ipm - duplex - colour
- Scanner Features
- Ultrasonic Double Feed Detection
- TWAIN, ISIS
Media Handling
- Max Document Size
- 279 mm x 432 mm
- Plain paper
- Automatic
- 200 sheets
- Ultra SCSI - HD-68 , USB 2.0 - Type B
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 216 Watt (6 Watt)
- Software Included
- ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 30 cm
- 17 cm
- 30 cm
- 17 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 53 dB
