Fuji FinePix JX650 White Camera Kit inc 8GB SD Card and Case
Quicklinx: 9KHJWS00 Mfr#: P10NC10710A 8GBCASE
  • SDHC Memory Card
6M, Wide-angle 26mm*** & 5x Optical Zoom Lens
16 million pixels* sensor produces high-quality, low-noise results at sensitivities of up to ISO 3200 (not available at some image sizes).
Image stabilization reduces camera and subject blur.
Automatic Scene Recogniton ensures the optimum camera settings are always deployed for the best images of a given scene .
*** 35mm format equivalent
Easy-to-Understand Menus
Thanks to the simple screen design, the menus are easy to use.
The bright, clear high-resolution 3.0-inch**, 230K-dot LCD monitor is easy to read.
Versatile Shooting Mode
  • Advanced filter(6 special effects) "Toy Camera","Miniature","Pop Color","Soft Focus","Cross Screen","Partial Color".
  • Individual shutter 3D
  • Motion Panorama
  • Face detection
  • Red-eye removal in detected faces
  • Blink detection
  • Smile & shoot mode
  • Tracking auto focus
  • Natural Light and with Flash
HD Movie (720p/30fps)
Record High Definition movies with a movie scene recognition function(1,280 X 720 pixels) or shoot photos with aspect ratios of 16:9.
Movie recording uses a dedicated button, allowing you to go from taking photographs to shooting movies at the press of a button. The cameras also incorporate a number of advanced movie-editing features, including "movie trimming" to cut unwanted footage from movies, and "movie join" to join multiple separate clips into a single movie.
Other Functions
Micro thumdnail view
Easy web uploading to YouTube™ & FACEBOOK
Photobook Assist
The battery charges when the camera is connected via USB.
Optical Zoom
5x
Megapixel
16 Megapixels
Movie Mode
720p
Image Sensor
CCD
Lens
Focal Length 4.6 - 23mm (equivalent to 26 - 130mm in 35mm format)
Shutter Speeds
1/4 sec
Auto Sensitivity
ISO 100 - 3200
Power Supply
Lithium-Ion Battery
I/O terminal
USB
Media Interface
SD, SDHC, SDXC
