Fuji FinePix AX650 Red Camera Kit including 4GB SD Card, Case, AA Batteries and Charger
Quicklinx: 90RFWS00 Mfr#: P10NC10540A-4GBCASE4AA
  • SDHC Memory Card
Designed to be the ultimate in simplicity, the easy-to-use AX650 features a 16-megapixel CCD sensor that captures large, high quality images, a precision Fujinon 5x optical zoom that Lens brings the action closer, and a bright 2.7" LCD makes shooting and viewing a snap. The AX650 also features the SR AUTO function which allows the camera to automatically determine difficult shooting conditions and maximize performance, for a great shot time after time. Combine all this with the convenience of AA battery operation for a simple to use value solution for the everyday picture taker.
  • Fujinon 5x zoom lens and 14 megapixels
    Fujinon lens, the high precision optic lens from Fujifilm, has received positive praise when used in various industries - satellite in outer space, TV/film, surveillance, and compact cameras. The technology provides great wide angle (1x) and 5x optical zoom.
  • High sensitivity ISO3200
    With maximum sensitivity of ISO3200, photos appear natural and more true-to-life even with limited available light. High sensitivity also stops the action of high-speed moving subjects.
  • Digital image stabilization
    Automatically detects blurred subjects and instantaneously increases shutter speed to ensure crisp, sharp images.
  • 2.7-inch monitor
    Brighter LCD screen gives you vivid color reproduction and is easier to see in outdoor situations. Sharing pictures is a pleasure, thanks to a high-impact 230,000-dot resolution.
Fujifilm FinePix AX650 - digital camera - Fujinon
Digital camera - 720p - compact
Lens Included
Fujinon
Memory Card Slot
SD card
Sensor Resolution
16.0 Megapixel
Max Video Resolution
1280 x 720
Lens System
Zoom lens - 5x zoom - 5.9 - 29.5 mm - f/3.3-5.9
Focus Adjustment
Automatic
Min Focus Distance
45 cm
Digital Zoom
7.2x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
2 x AA alkaline battery (included) , AA NiMH rechargeable battery (optional)
Composite video/audio, USB 2.0
Red
9.3 cm x 2.78 cm x 6.02 cm
119 g
Lens Included
Fujinon
Enclosure Colour
Red
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
CCD
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
3200
Optical Zoom
5x
Digital Zoom
7.2x
Image Stabiliser
Electronic
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
AE/AF Control
Subject-tracking AF
Face Detection
Blink Detection technology, Smile Capture
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
1280 x 720
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto, ISO 3200 (4MP)
Exposure Metering
Multi-segment
Exposure Metering Zones
256
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, night mode, text, party/indoor, fireworks, flower, sports mode, sunset, beach, night (tripod), natural light, snow, baby, natural light & with flash, smile shot, motion panorama
White Balance
Automatic, presets
White Balance Presets
Fine, incandescent, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white)
Max Shutter Speed
1/1400 sec
Min Shutter Speed
8 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Fujinon zoom lens - 5x zoom - 5.9 - 29.5 mm - f/3.3-5.9
Focal Length Equivalent to 35mm Camera
33 - 165mm
Focus Adjustment
Automatic
Min Focus Distance
45 cm
Macro Focus Range
10cm
Zoom Adjustment
Motorised drive
Lens Construction
8 groups / 8 elements
Built-in lens shield
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Effective Flash Range
0.6 m - 4.2 m: ISO auto (wide lens) , 0.6 m - 2.8 m: ISO auto (tele lens) , 0.3 m - 1 m: ISO auto (macro lens)
Additional Features
Self-Timer Delay
10 sec, 2sec
Additional Features
RGB primary colour filter, digital image rotation, in-camera red-eye removal, cropping an image, resizing an image, Automatic Scene Recognition (SR Auto), Motion Panorama
Display
2.7" LCD display
Display Format
230,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output
Software
Software
Drivers & Utilities
Hand strap, USB cable
Battery Type
AA - Alkaline - standard form factor
Details
Battery Life Details
Photo shooting - 160 shots (alkaline batteries) , Photo shooting - 420 shots (NiMH batteries)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDHC Memory Card
Image Storage
JPEG 4608 x 3440 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3264 x 2448 , JPEG 3072 x 1728 , JPEG 2304 x 1728 , JPEG 1920 x 1080
Video Capture
AVI - 1280 x 720 - 30 fps , AVI - 640 x 480 - 30 fps , AVI - 320 x 240 - 30 fps
9.3 cm
2.78 cm
6.02 cm
119 g
10 - 80% (non-condensing)
