This TFX power supply unit (PSU) has a real power rating. The eco-friendly design allows GHT series to reach high efficiency. GHT series is ideally suited for small form factor applications. The flat fan design allows easy assembly into the vast majority of TFX chassis. GHT series also protects your PC by providing complete protection.
- FSP FSP250-60GHT - power supply - 250 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- TFX12V 2.1
- 80 PLUS Certification
- 80 PLUS
- Input Voltage
- AC 90-264 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 250 Watt
- Output Current
- +3.3V - 14 A , +5V - 16 A , +12V1 - 14 A , +12V2 - 16 A , -12V - 0.5 A , +5VSB - 2 A
- 8.5 cm x 17.5 cm x 7 cm
- TFX12V 2.1
- PSU Form Factor
- TFX
- Input Voltage
- AC 90-264 V
- Frequency Required
- 50/60 Hz
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 250 Watt
- Max Spike Voltage
- 1800 V
- Output Current
- 80 PLUS
- MTBF
- 100,000 hours
- Over current protection, over voltage protection, short-circuit protection, re-settable power shut down, non-modular
- CB, FCC
- 0 °C
- 50 °C
- 8.5 cm
- 17.5 cm
- 7 cm
