The Fractal Design Edison M series of power supplies feature excellent electrical performance, including 80PLUS Gold certified efficiency.
Designed for maximum reliability, the Edison M units feature Japanese electrolytic capacitors with a full protection suite, including over-temperature protection. The modular cable system assists with a clean installation and the extra-long ATX 12 V cable accommodates cases with bottom mounted PSU positions.
Fractal Design Edison M units are equipped with a large, temperature-controlled FDB-bearing 120 mm fan contributing to a maximum lifespan while keeping noise levels at a minimum.
The Edison M is a highly reliable choice, for both gaming computers and powerful workstations.
80 PLUS Gold certified efficiency
Edison M PSUs meet the 80 PLUS Gold specification for providing power at an extremely competitive price point, priving excellent value. Additionally, because Edison M PSUs generate less heat, they provide power at lower fan speeds, which results in reduced noise levels. -
Superb Electrical Performance
Fractal Design Edison M Series PSUs feature excellent DC voltage regulation and ripple suppression: they can deliver their full-rated wattage continuously even with an intake temperature as high as 40 °C at full load or 50 °C at 80% load. -
Compliant with the latest standards
Edison M PSUs are compliant with the PC PSU standard: ATX 2.4/EPS 2.92. -
High end capacitors
Edison M PSUs feature Japanese electrolytic capacitors, rated at 105 °C as well as Japanese and Taiwanese solid polymer capacitors. -
Silent, temperature-controlled 120 mm FDB fan
Generally, larger fans move more air with less noise than smaller fans: Edison M Series PSUs are equipped with a 120 mm FDB bearing, which keeps noise levels at a minimum. -
Extra-long ATX 12 V cable
Edison M PSUs are equipped with an extra long 12 V connector cable, which accommodates bottom-mounted-PSU computer cases. -
Computer protection
Edison M PSUs feature a full suite of computer protection, including: Over Power Protection, Over Voltage Protection, Short Circuit Protection, Under Voltage Protection, Over Current Protection and Over Temperature Protection.
- Fractal Design Edison M 750W - power supply - 750 Watt
- Power supply - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 2.5 kg
- Localisation
- United Kingdom
- Power Capacity
- 750 Watt
- Output Current
- +3.3V - 20 A , +5V - 20 A , +12V1 - 62 A , -12V - 0.3 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 10 x 15 pin Serial ATA power , 5 x 4 PIN internal power , 1 x power 8 pin EPS12V
- Modular Cable Management
- Cooling System
- 120 mm fan
- Included Accessories
- Cable ties
- Black
- 15 cm x 16 cm x 8.6 cm
- 5-year warranty
- PSU Form Factor
- ATX
- Black
- Localisation
- United Kingdom
- Power Output Connectors Details
- Power Capacity
- 750 Watt
- Output Current
- 80 PLUS Gold
- Cable ties
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, DC-DC technology, Intel 4th-gen CPU (Haswell) compatible, fluid dynamic bearing cooling fan
- ErP 2013
- Limited warranty - 5 years
- 40 °C
- 15 cm
- 16 cm
- 8.6 cm
- 2.5 kg
- Shipping Width
- 29.9 cm
- Shipping Depth
- 12.2 cm
- Shipping Height
- 18.5 cm
- Shipping Weight
- 3.1 kg
