Fractal Design Newton R3 series power supply units (PSUs) provide clean power efficiently and silently. The Newton R3 is the ultimate choice for demanding high-end gaming computers and ultra-quiet media PCs.
The visual appearance of Newton R3 series PSUs is proof of fractal design's commitment to providing innovative computer components infused with stylish, elegant, contemporary Scandinavian design.
80 PLUS platinum certified efficiency
Newton R3 series PSUs meet the high efficiency specifications currently available for consumer-grade power supplies. This efficiency produces both positive environmental impacts, as well as reduces electricity bills. Additionally, because the Newton R3 series PSUs generate less heat, they provide power at lower fan speeds, which results in reduced noise levels. -
Excellent electrical performance
Newton R3 series PSUs feature excellent DC voltage regulation and ripple suppression; they can deliver their full-rated wattage continuously even with an intake temperature. -
SLI and CrossFireX support
Newton R3 series PSUs are tested and certified compatible with the latest graphics cards. -
Modular cables
With the exception of a few, all cables on the Newton series power supplies can be detached from the PSU unit. This reduces the clutter, assists with a clean installation and improves the airflow in the computer case. -
Semi-passive fan operation
Newton R3 series PSUs generate very little heat, they work well without active cooling in most environmental and loading conditions, especially in a well-ventilated case. Subsequently, Newton R3 Series PSUs are equipped with temperature sensors that only start the fan when required to keep the operating temperature down.
- Fractal Design Newton R3 800W - power supply - 800 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Platinum
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 800 Watt
- Output Current
- +3.3V - 20 A , +5V - 20 A , +12V - 66 A , -12V - 0.5 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 8 pin EPS12V , 6 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- Included Accessories
- Cable ties
- Black
- 15 cm x 16.5 cm x 8.6 cm
- 5-year warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 800 Watt
- Output Current
- 80 PLUS Platinum
- Cable ties
- Cables Included
- Power cable
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- SLI ready, cable management, single 12V rail, temperature controlled fan, ball bearing cooling fan, CrossFireX ready
- Limited warranty - 5 years
- 15 cm
- 16.5 cm
- 8.6 cm
- Shipping Width
- 44.5 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 23.5 cm
