Evoluent Hypertec Evoluent VerticalMouse 4 - Right Handed
Quicklinx: 9QRFWS00 Mfr#: VMOUS4RLHY
The patented shape of the mouse supports your hand in an upright neutral posture that generally avoids forearm twisting. Many users, including medical doctors, ergonomists and physical therapists, said the Evoluent VerticalMouse provides superior comfort and even relieved their wrist pain.
  • Comfortable and easy to use
    The shape is thoughtfully sculpted for uncompromised comfort and easy-to-reach programmable buttons. No finger contortions are needed to operate the buttons.
  • Adjustable laser sensor
    Pointer speed controls on the side allow convenient adjustment without even releasing your grip from the mouse.
  • Improved thumb rest
    The thumb rest has been reshaped to provide even more comfort over earlier versions.
  • Pointer speed indicators
    Top mounted LEDs show through the chrome thumb rest to indicate selected pointer speed including extra low (XL), low (LO), MD (medium), to high (HI).
  • Now two thumb buttons
    A bottom thumb button provides greatly extended functionality when used with the included driver.
  • Lighted Evoluent logo
    The logo is pure eye candy. The illumination turns off when the system is in sleep mode to conserve notebook battery power.
  • Extended lip prevents rubbing
    An extra wide lip along the bottom edge prevents the last finger from rubbing the desk.
  • Powerful and intuitive driver
    Evoluent mouse manager for Windows provides extensive but easy to use functionality for 6 buttons through a simple and intuitive interface.
Evoluent VerticalMouse 4 Right - mouse - USB - grey, silver
Mouse
Wired - USB
Grey, silver
Orientation
Right-handed
8.9 cm x 11.1 cm x 8 cm
135 g
Movement Detection Technology
Laser
Buttons Qty
6
Programmable buttons, scrolling wheel, vertical, switchable resolution, Click lock, Auto click, illumination, Pointer speed indicators
1 x mouse cable - integrated
Linux, Microsoft Windows XP, Apple MacOS X or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
Mouse
Orientation
Right-handed
8.9 cm
11.1 cm
8 cm
135 g
Grey, silver
Input Device
Wired
USB
Laser
Buttons Qty
6
1 x mouse - USB - 4 pin USB Type A
