The unbeatable performance of the EVGA SuperNOVA P2 power supply line is now available in 850 watts. Based on the award winning P2 power supplies, this unit features 80 Plus Platinum rated efficiency, and clean, continuous power to every component. The ECO Control Fan system offers fan modes to provide absolutely zero fan noise during low load to medium load operations. Backed by an award winning 10 year warranty, and 100% Japanese capacitor design, the EVGA SuperNOVA 850 P2 power supply offers unbeatable performance at an unbeatable value.
FEATURES
Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
80 PLUS Gold certified, with 90% (115VAC) / 92% (220VAC~240VAC) efficiency or higher under typical loads
Highest quality Japanese brand capacitors ensure long term reliability
Fully Modular to reduce clutter and improve airflow
NVIDIA SLI & AMD Crossfire Ready
Double Ball Bearing fan for exceptional reliability and quiet operation
Heavyduty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
- EVGA SuperNOVA 850 P2 - power supply - 850 Watt
- Power supply - internal
- Specification Compliance
- ATX / EPS
- 80 PLUS Certification
- 80 PLUS Platinum
- 3.63 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 Watt
- Output Current
- +5V - 20 A , +3.3V - 20 A , +12V - 70.8 A , -12V - 0.5 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 10 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 140 mm fan
- Included Accessories
- Cable bag
- 15 cm x 16.5 cm x 8.5 cm
- 10-year warranty with product registration
- ATX / EPS
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 Watt
- Output Current
- Efficiency
- 92% (115VAC) / 94% (220-240VAC)
- 80 PLUS Platinum
- Cable bag
- MTBF
- 100,000 hour(s)
- Cooling System
- 140 mm fan
- Over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, Eco-Mode, fully modular
- TUV, BSMI, CB, FCC, RoHS, WEEE, cTUVus, Energy-Related Products (ErP) Lot 6, RCM
- Limited warranty - parts and labour - 10 years with product registration
- 0 °C
- 50 °C
- 15 cm
- 16.5 cm
- 8.5 cm
- 3.63 kg
