90% efficiency or higher under typical loads and the highest quality Japanese brand capacitors ensure long-term reliability.
Semi-modular design allows you to only use the cables you need, helping to improve case airflow, eliminate unnecessary wires, and best of all. reduce cable clutter.
The EVGA ECO mode feature ensures that the power supply stays completely silent during low to medium loads. The fan does not spin until necessary, allowing for completely silent operation!
Unrivaled performance
90% efficiency or higher under typical loads and the highest quality Japanese brand capacitors ensure long-term reliability. -
Modular design
Semi-modular design allows you to only use the cables you need, helping to improve case airflow, eliminate unnecessary wires, and best of all. reduce cable clutter. -
Whisper silent
- EVGA 1000 GQ - power supply - 1000 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V / EPS12V
- 80 PLUS Certification
- 80 PLUS Gold
- 3.18 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1000 Watt
- Output Current
- +3.3V - 24 A , +5V - 24 A , +12V - 83.3 A , +5VSB - 3 A , -12V - 0.5 A
- Output connectors
- 1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 10 x 8 pin PCI Express power with detachable 2 pin section , 12 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 2 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- 15 cm x 16.5 cm x 8.5 cm
- 5-year warranty
- ATX12V / EPS12V
- PSU Form Factor
- ATX
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1000 Watt
- Output Current
- Efficiency
- 90% (115VAC) / 92% (220-240VAC)
- 80 PLUS Gold
- Cables Included
- Power cable - external - 1.53 m
- MTBF
- 100,000 hour(s)
- Cooling System
- 135 mm fan
- Overheat protection, solid capacitors, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, active CLAMP circuitry, Eco-Mode, Intel 4th-gen CPU (Haswell) compatible, fluid dynamic bearing cooling fan, semi-modular
- TUV, CB, FCC, RoHS, WEEE, cTUVus, ErP 2013, RCM
- Limited warranty - parts and labour - 5 years
- 0 °C
- 50 °C
- 15 cm
- 16.5 cm
- 8.5 cm
- 3.18 kg
