Introducing the EVGA GeForce GTX 980 Ti Superclocked+ . Accelerated by the groundbreaking NVIDIA Maxwell architecture, GTX 980 Ti Superclocked+ delivers an unbeatable 4K and virtual reality experience. With 2816 NVIDIA CUDA Cores and 6GB of GDDR5 memory, it has the horsepower to drive whatever comes next. In fact, the EVGA GeForce GTX 980 Ti Superclocked+ provides 3x the performance and 3x the memory of previous-generation cards. You can now take on even the most challenging games at high settings for a smooth, ultra high-definition, 4K experience.
This card also features EVGA ACX 2.0+ cooling technology. EVGA ACX 2.0+ brings new features to the award winning EVGA ACX 2.0 cooling technology. A memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 13%, and optimized Straight Heat Pipes (SHP) reduce GPU temperature by an additional 5C. ACX 2.0+ coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
- EVGA GeForce GTX 980 Ti Superclocked+ ACX 2.0+ - graphics card - GF GTX 980 Ti - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 980 Ti
- Memory
- 6 GB GDDR5
- Core Clock
- 1102 MHz
- Boost Clock
- 1190 MHz
- CUDA Cores
- 2816
- Effective Memory Clock
- 7.01 GHz
- Memory Interface
- 384-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- DVI-I (dual link) , 3 x DisplayPort , HDMI
- API Supported
- OpenCL, DirectX 12, OpenGL 4.5
- 26.67 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1102 MHz
- Boost Clock
- 1190 MHz
- CUDA Cores
- 2816
- Max Resolution
- 4096 x 2160 at 240 Hz
- 4
- API Supported
- Nvidia CUDA technology, Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 384-bit
- Bandwidth
- 336.5 GBps
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- Required Power Supply
- 600 W
- Additional Requirements
- 6 pin PCI Express power connector, 8 pin PCI Express power connector
- Software Included
- EVGA Precision X, EVGA OC Scanner X
- 26.67 cm
- 11.115 cm
- Limited warranty - 3 years
