The EVGA GeForce GTX 960 delivers incredible performance, power efficiency, and gaming technologies that only NVIDIA Maxwell technology can offer. This is the perfect upgrade, offering 60% faster performance and twice the power efficiency of previous-generation cards. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC technology, and Dynamic Super Resolution for 4K-quality gaming on 1080P displays.
TheEVGA ACX 2.0+ cooler brings features to the award winning EVGA ACX 2.0 cooling technology. A Memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 11°C, and optimized Straight Heat Pipes (SHP) reduce GPU temperature by an additional 5°C. ACX 2.0+ coolers also feature optimized Swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
dBi - dB Noise Inverter
EVGA's ACX 2.0+ fan turns off below 60°C, generating 0dB of noise. -
MMCP - Memory MOSFET Cooling Plate
Full size cooling plate makes direct contact with memory and MOSFETS, reducing memory up to 9°C and MOSFET up to 11°C. -
QSD BIOS - Quick Switch Dual BIOS
Multiple integrated BIOSes allow you to switch to the secondary with the flick of a switch. -
OPT - Optimized Power Target
The power target is precisely tuned for the perfect balance of thermal, power and performance, offering more power over reference. -
SHP - Straight Heat Pipes
Triple 8mm straight heat pipes offer better heat dissipation than bent heat pipes with reduced thermal resistance.
- EVGA GeForce GTX 960 SuperSC ACX 2.0+ - graphics card - GF GTX 960 - 4 GB - black
- Graphics card
- Bus Type
- PCI Express 3.0
- Graphics Engine
- NVIDIA GeForce GTX 960
- Memory
- 4 GB GDDR5
- Core Clock
- 1279 MHz
- Boost Clock
- 1342 MHz
- CUDA Cores
- 1024
- Effective Memory Clock
- 7010 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2048 x 1536 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
- Max Monitors Supported
- 4
- 3 x DisplayPort , DVI-I (dual link) , HDMI
- API Supported
- OpenCL, OpenGL 4.4, DirectX 12
- 25.65 cm x 11.115 cm
- Enclosure Colour
- Black
- 3-year warranty
- Graphics card
- Bus Type
- PCI Express 3.0
- Graphics Engine
- Core Clock
- 1279 MHz
- Boost Clock
- 1342 MHz
- CUDA Cores
- 1024
- Max Resolution
- 4096 x 2160 at 240 Hz
- 4
- API Supported
- Nvidia CUDA technology, Nvidia Surround technology, Dual Fan Design, Nvidia SLI ready, x.v.Color technology, Deep Color technology, Blu-Ray 3D Support, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, 7.1 channel surround sound ready, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks, eVGA Active Cooling Xtreme (ACX) 2.0, Straight heatpipes (SHP), Quick Switch Dual BIOS (QSD), Optimized Power Target (OPT), Memory MOSFET Cooling Plate (MMCP), dB Noise Inverter (dbi), EVGA Backplate
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7010 MHz
- Bus Width
- 128-bit
- Bandwidth
- 112.16 GBps
- OS Required
- Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Required Power Supply
- 400 W
- Additional Requirements
- Adjacent PCI slot
- Software Included
- EVGA Precision X, EVGA OC Scanner X
- 25.65 cm
- 11.115 cm
- Enclosure Colour
- Black
- Limited warranty - parts and labour - 3 years
