The EVGA GeForce GTX 760 is the new weapon of choice for gamers - a powerful graphics card that gives you the fast, smooth, quiet gaming you're looking for in all your favorite titles.
EVGA is also extending the award winning ACX Cooling to the EVGA GeForce GTX 760 line. With a 40% increase in heatsink volume, the EVGA ACX is more efficient at dissipating heat, allowing for 15% lower GPU temperatures.
Even the fan blades are of the highest quality; with a 700% increase in strength, and 25% lower weight when compared to competitors. This makes the fans 20% more efficient by requiring lower power levels. EVGA is also using double ball bearing fans which offer a 12 year lifespan, 4X longer when compared to competitors!
Core
- 1152 CUDA Cores
- Base Clock: 1072 MHz
- Boost Clock: 1137 MHz
- Bus: PCI-E 3.0
- 2-way, 3-way SLI Ready
- Texture Fill Rate: 102.9 GT/s
- Memory Detail: 2048 MB GDDR5
- Memory Bit Width: 256 Bit
- Memory Clock: 6008 MHz
- Memory Speed: 0.33 ns
- Memory Bandwidth: 192.2 GB/s
Key Features
- NVIDIA TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays; two dual-link DVI connectors, HDMI and Displayport 1.2
- Microsoft DirectX 11.1 API (feature level 11_0) with Direct Compute 5.0 support
- NVIDIA 3D Vision Ready
- NVIDIA SLI Ready
- NVIDIA CUDA Technology
- PCI Express 3.0 Support
- OpenGL 4.3 Support
- OpenCL Support
NVIDIA PhysX technology
Full support for NVIDIA PhysX technology, enables a class of physical gaming interaction for a more dynamic and realistic experience with GeForce. -
NVIDIA SLI ready
Industry leading NVIDIA SLI technology offers amazing performance scaling by implementing AFR (Alternate-Frame-Rendering) for the world's premier gaming solution under Windows 7 with solid, state-of-the-art-drivers. -
NVIDIA SMX engine
Next generation streaming multiprocessor built from the ground up for incredible performance and power efficiency. -
NVIDIA GPU boost
Dynamically maximizes clock speeds based on workload of the game to push performance to new levels and bring out the best in every game. -
NVIDIA adaptive vertical sync
Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. -
NVIDIA surround
With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. NVIDIA Surround also supports triple screen gaming with non-3D Vision monitors. Add in a fourth accessory display to get access to your email, web, or other applications while you game. -
DirectX 11.1 API (feature level 11_0) GPU with Shader Model 5.0 support designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation. -
NVIDIA 3D vision ready
Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D. -
NVIDIA CUDA technology
Unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivers incredible performance improvements over traditional CPUs. -
PCI Express 3.0 support
Designed for the PCI Express 3.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support. -
NVIDIA FXAA technology
Shader-based anti-aliasing technology available from the NVIDIA control panel enables ultra-fast anti-aliasing in hundreds of PC games. -
NVIDIA TXAA technology
Support for new temporal anti-aliasing technique that delivers the ultimate combination of image quality and performance. -
NVIDIA PureVideo HD technology
The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
- EVGA GeForce GTX 760 Superclocked - graphics card - GF GTX 760 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 760
- Memory
- 2 GB GDDR5
- Core Clock
- 1072 MHz
- Boost Clock
- 1137 MHz
- CUDA Cores
- 1152
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort , VGA - with adapter
- API Supported
- OpenCL, DirectCompute 5.0, DirectX 11.1, OpenGL 4.3
- 24.1 cm x 11.115 cm
- 3-year warranty with product registration
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1072 MHz
- Boost Clock
- 1137 MHz
- CUDA Cores
- 1152
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, x.v.Color technology, Deep Color technology, Blu-Ray 3D Support, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 256-bit
- Bandwidth
- 192.2 GBps
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- Required Power Supply
- 500 W
- Additional Requirements
- 6-pin + 8-pin power connectors
- 170 Watt
- Included Accessories
- Dual 6-pin PCIe to 8-pin power adapter, EVGA Accessory Pack, Dual 4 pin to 6 pin power cable
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
- 24.1 cm
- 11.115 cm
- 1.36 kg
- Limited warranty - 3 years
